no power at all
Old Nov 20, 2005 | 05:34 PM
civickiller's Avatar
Default no power at all
this is a 91 civic 4 door lx.
the car has no power at all, nothing. headlights, radio, starter. nothing at all. just got a new alt and battery on it. fuses under the hood were all good. any ideas ?
Old Nov 20, 2005 | 06:12 PM
sam385's Avatar
Default Re: no power at all (civickiller)
did you check the main fuse(s) in the block under the hood?
also check to make sure all ground straps are in place
Old Nov 20, 2005 | 11:05 PM
Default Re: no power at all (sam385)
main fuses under the hood are all good.
i know hte battery and valve cover grounds are good. ill check the thermostat ground
Old Nov 20, 2005 | 11:57 PM
31flavorscivic's Avatar
Check to make sure the negative cable is properly grounded.
I was going to say the 50a ignition fuse but since the headlights arent working either I guess that's out.
Old Nov 21, 2005 | 12:48 AM
Default Re: no power at all (31flavorscivic)
ignition fuse, is that in the fuse box under the hood? if so all the fuses under there were good.
but i gotta go check out the headlight part because the info i got was from a girl so maybe she was just agreeing with what i asked her. it might be just ignition things not working
it was working fine before, then it had starting problems, and now no power at all
Taylor1976
May 13, 2018 04:05 PM
KcAccord
Feb 28, 2015 06:03 AM
mikeycivic
Audio / Security / Video
Apr 13, 2010 10:57 AM
VTECengaged
Apr 26, 2009 01:52 PM
young geezer
May 20, 2007 09:15 AM
