how to fix passenger coupe seat in my 94+ integra
i took out the passenger seat and now when i put it back and i pull the side handle.. the seat doesn't slide forward anymore for the rear people to get in... just wondering if there something i tripped ?
I would remove the seat again and check to see if anything is obstructing the rail. More then likely theres something the got jammed in the way when your were moving it around. Also if you have a amp or anything else under there that would be in the way.
there is a wire/cable that connects both sides of the seat rails.. make sure those are connected.. and look under to see if anything else appears stuck or if any springs came out..
add to the above, check the cable. it should have a yellow or green color tab/hook. you probably somehow got that unhooked
welll i did that pull on the way back thing... it didnt' work.. lemme check for yellow/green tag thing tomorrow.. thanks
hmz i'm saying if i pull the handle under your feet, it WILL move forward, but i'm talking bout the convience when you pull the side handle and it should automatically slide forward for back seaters to get in. =T
o man..i got the same problem..i have no idea what i did wrong. can someone please help. it may be the cable thing..maybe it hooked up wrong? where does it start and where is it suppose to go? thanks
yes this also has happened to me when i installed the del sol seat..
wut is even worse is the fact that when i pull the right hand side lever.. the LEFT rail.. feels like it can move.. whereas the problem is on the right hand side lever..
CloudCover
Honda Accord (2013 - 2015)
Apr 28, 2018 03:18 PM
