CIVIC HX's WHEELS FIT 94 LS INTEGRA?
Old Nov 20, 2005 | 12:54 PM
Po0r LiTTle CoUpe's Avatar
Default CIVIC HX's WHEELS FIT 94 LS INTEGRA?
heard they wonlt... just wondering....
thanks
-randy
Old Nov 20, 2005 | 01:02 PM
mjc1055's Avatar
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (Quick Hatch)
As long as they're 14's, they'll fit. I believe the HX came with 14's and the VXs came with 13s, so they should be fine.
Old Nov 20, 2005 | 01:06 PM
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (mjc1055)
yea hx's are 14's but somone told me they rub the brakes or somthing...
Old Nov 20, 2005 | 01:07 PM
mjc1055's Avatar
14s will clear the brakes, 13s will not, which is what I was trying to say in my last post.
Old Nov 20, 2005 | 01:42 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">14s will clear the brakes.</TD></TR></TABLE>
hey , rocket scientist , theres more to it than simply diameter. Its that offset thing that causes problems in this case.
Old Nov 20, 2005 | 01:52 PM
mjc1055's Avatar
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (Doctor CorteZ)
Really? I've run 14" steelies before without problems, I would've assumed them to be the same. Also, I've seen pictures of an integra on here before that had hx wheels on it.
And also, it's possible to correct somebody without trying to attack them. But apparently that's beneath you.
Old Nov 20, 2005 | 02:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">Really? I've run 14" steelies before without problems, I would've assumed them to be the same. Also, I've seen pictures of an integra on here before that had hx wheels on it.
yeah , steelies are no prob. HX wheels are a different animal , the thickness of the spokes vs the steels is what gets you. You can grind a mm or two off the caliper face and they'll work fine...or spacers but then they become lugcentric which I dont care for.
And also, it's possible to correct somebody without trying to attack them. But apparently that's beneath you.</TD></TR></TABLE>
apparently it is.
you answered without the correct information and treated an assumption as fact , thats how all this misinformation spreads.
Old Nov 20, 2005 | 02:38 PM
ok so.. no they wonlt?
Old Nov 20, 2005 | 03:14 PM
mjc1055's Avatar
Apparently they will not without modification to the caliper.
Old Nov 20, 2005 | 03:18 PM
loudassVTEC's Avatar
They wouldn't fit on my DA. I borrowed my friends drag radials mounted on them, and it rubbed the calipers in the front.
Old Nov 20, 2005 | 03:25 PM
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (loudassVTEC)
whitty?
Old Nov 20, 2005 | 03:42 PM
Yeah, this is whitty...who's this??
Old Nov 20, 2005 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, this is whitty...who's this??
randy fool...
Old Nov 20, 2005 | 03:52 PM
pm'd you
Old Nov 20, 2005 | 03:55 PM
gotparts's Avatar
I have hx on my integra.....i just ride it and go fast on the fwy until the brake shaves a small size of the rim evenly, but just kep on tightning the lugs. it shaves off a couple of grams and i have no problems with it...been running it for 2 yrs
Old Nov 20, 2005 | 04:08 PM
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (gotparts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotparts &raquo;</TD></TR><TR><TD CLASS="quote">I have hx on my integra.....i just ride it and go fast on the fwy until the brake shaves a small size of the rim evenly, but just kep on tightning the lugs. it shaves off a couple of grams and i have no problems with it...been running it for 2 yrs</TD></TR></TABLE>
LoL
Old Nov 20, 2005 | 04:09 PM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">Apparently they will not without modification to the caliper.</TD></TR></TABLE>
haha OWNED
Old Nov 20, 2005 | 08:41 PM
x_tc-Dae's Avatar
LOL + 2
Old Nov 20, 2005 | 09:16 PM
Downey's Avatar
whoa.. that sounds kinda dangerous.
why not just run a small wheel spacer (5mm or somthing similar) that would be much easier and safer.
id even run 4 evenly think washers on the wheel studs if i had to as last resort.
Old Nov 21, 2005 | 01:48 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
lol
Old Nov 21, 2005 | 04:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick Hatch &raquo;</TD></TR><TR><TD CLASS="quote">ok so.. no they wonlt?</TD></TR></TABLE>
did you even read what I wrote ?
christ.
Old Nov 21, 2005 | 04:49 PM
-Todd-'s Avatar
Quoted, I needed something in my sig.
Old Nov 21, 2005 | 05:06 PM
coot_er's Avatar
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (-Todd-)
Old Nov 21, 2005 | 05:37 PM
nafreak's Avatar
Default Re: CIVIC HX's WHEELS FIT 94 LS INTEGRA? (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">why not just run a small wheel spacer (5mm or somthing similar) that would be much easier and safer.
id even run 4 evenly think washers on the wheel studs if i had to as last resort.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote"> You can grind a mm or two off the caliper face and they'll work fine...or spacers but then they become lugcentric which I dont care for.</TD></TR></TABLE>
Old Nov 21, 2005 | 07:00 PM
TSX TEX's Avatar
GTFO LMAO
