SOHC ZC passing CA smog?!
Hey all, I've searched and all I could really find were DOHC/B-series swaps trying to pass smog, but I was wondering how difficult/has anyone passed CA smog with a SOHC ZC motor? If so, how did you do it/how would you do it (any tricks/products/anything at all)? Thanks ahead of time.
I don't know if they can be BAR'd, but if you take it for an emissions test, and they don't read the block stamp, and you pass, then you've just passed smog with a SOHC ZC
Thanks for the quick replies. So I take it SOHC ZC engines don't produce much emission? If so, that's good news for me. I was getting panicked, because I dropped the money to import my civic, and I finally got it temp registered
non-Vtec I believe. My engine stamp just says "ZC," and it's an SOHC. There were some numbers under the "ZC" designation as well, but I'll see tomorrow morn'. I'm going to take my car to smog tomorrow so crossing my fingers that it'll pass.
sorry to bring this back but im having problems passing smog with my SOHC ZC non-vtec and its all stock... at first it didnt pass cuz my NOX was to high... so i changed my o2 and my cat... then did the basic tuneup oil change, spark plugs and air filer... took it the second time and still didnt pass?? at high rpms im running to lean from what the guy was tellin me??? anyway to solve this problem?? i was told to seafoam my motor???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil_ryu »</TD></TR><TR><TD CLASS="quote">sorry to bring this back but im having problems passing smog with my SOHC ZC non-vtec and its all stock... at first it didnt pass cuz my NOX was to high... so i changed my o2 and my cat... then did the basic tuneup oil change, spark plugs and air filer... took it the second time and still didnt pass?? at high rpms im running to lean from what the guy was tellin me??? anyway to solve this problem?? i was told to seafoam my motor??? </TD></TR></TABLE>
check your ECU and see if you are throwing a code 7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
check your ECU and see if you are throwing a code 7</TD></TR></TABLE>
but i dont get a CEL???
but i dont get a CEL??? </TD></TR></TABLE>
doesnt matter, code 7 wont trip the CEL, i found that out and i had the same problem as you when i first did my swap
I was thinking of doing the ZC swap but was worried about emissions as well. I have 2 friends who couldn't get their ZCs to pass unless they changed the cat out to a new one everytime they smog. Would swapping out the intake man and the tb possibly eliminate the need to do this everytime?
Plus I have no idea if they swapped those parts out or did a straight drop in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi »</TD></TR><TR><TD CLASS="quote">Hey all, I've searched and all I could really find were DOHC/B-series swaps trying to pass smog, but I was wondering how difficult/has anyone passed CA smog with a SOHC ZC motor? If so, how did you do it/how would you do it (any tricks/products/anything at all)? Thanks ahead of time. </TD></TR></TABLE>
The SOHC ZC is really just a D16A6 variant. It really looks no different from that particular motor. As long as you are running it with a USDM intake manifold, throttle body, and vacuum line configuration, your setup will not be questioned by a smog test station. They will think it is just a stock SI motor. So unlike a DOHC ZC or B-series swap, you will pass visual with no problems. As far as the tailpipe test, it should pass provided there are no problems.
i pass smog all the time, sohc zc non-vtec, d16a6 manifold, cat(passed twice with the same one) and Aem Cold air intake....passed with flying colors....there only problem i ever had was the first time i smogged it, my car was ideing to high....they said it was my timing, but i jus adjusted that lil air/idle contriol screw on the throttle body......as to why they say u r runing to lean at high rpm i duno....how high r they going? arent they suppoesd to jus run it at 15mph, then 25mph? i think the highest rpm the guy hit with mine was 3000 if that?
doesnt matter, code 7 wont trip the CEL, i found that out and i had the same problem as you when i first did my swap</TD></TR></TABLE>
ill have to check that out after work, thnxs man
yep
yep
Chewy Built !
Jul 2, 2007 09:48 PM
