Lug nuts for Wheel Covers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">Can I use the lugs that came with my stock alloy rims s to mount the hubcaps on my new stock winter steelies? ie, do I have to buy new lugs and the plastic washers or just the washers?
My car looks kinda ghetto on bare steelies...though maybe less likely to be stolen
Have you seen the wheel covers yet? Most aftermarket wheel covers do not attach with the lug nuts, which means that the wheel covers have nothing to do with what lug nuts you use.
However, make sure the seating area of your lug nuts is the same shape as the seating area of your wheels. (The seating area is the area where the two pieces are in contact with each other.) Steel wheels may have a ball (acorn) shaped seating area, like stock Honda/Acura wheels, or they may have a tapered (conical) shaped seating area, like aftermarket wheels. Whichever they have, make sure you use lug nuts to match.
If you need to buy more lug nuts, aftermarket ones are only around $1-2 each ($1.19 at Autozone) and you can get either kind.
</TD></TR></TABLE>Have you seen the wheel covers yet? Most aftermarket wheel covers do not attach with the lug nuts, which means that the wheel covers have nothing to do with what lug nuts you use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">Factory hubcaps require different lugs that have plastic clips built into them. $30 for a set from Honda. Cant get em anywhere else.</TD></TR></TABLE>
Yup - that's the correct answer. (I just found out about this myself.)
