garrett t3 turbo .42 .48
t3 turbo 42/48. no shaft play at all. has 5 bolt exhaust housing that measures 4 3/4" fron the 2 longest bolts (there are 2 different 5 bolt patterns). comes with metal gasket for t3 inlet, and also comes with internal wastegate assembly.
would like 225 shipped.
to view pics you have to copy and paste the links into your web browser.
http://d0nfry.sphosting.com/turbo1.jpg
http://d0nfry.sphosting.com/turbo2.jpg
http://d0nfry.sphosting.com/misc.JPG (internal wg assembly pictured)
there was a tiny amount of play when i first got the turbo, it hadn't seen oil in a while. which in 1 min of starting my car with the turbo on, it saw oil, and there is absolutely no play, side to side or in/out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 »</TD></TR><TR><TD CLASS="quote">shaft play? can i get a pic of the 5bolt pattern? i'm interested w/o the wg</TD></TR></TABLE>
sry i don't have a pic of the bolt pattern. there are 2 different size 5 bolt t3 patterns though. i take it your asking cause you have a downpipe already. measure the bolt holes furthest apart from each other on the turbo. check this pic.
http://d0nfry.sphosting.com/t3downpipeflange.bmp paste that into your browser.
if you need a downpipe, i have everything you need to make one pictured here
http://d0nfry.sphosting.com/downpipe.jpg
(copy and paste)
(copy and paste)
HT Username
May 6, 2005 09:55 PM
b18c1crx
Jun 17, 2003 08:49 PM
