1st time @ track last night.
Old Nov 20, 2005 | 09:00 AM
heyitzspikey's Avatar
Default 1st time @ track last night.
well my time was not what i though my car should run what am i doing wrong? this is my time..R/T=.847
60=2.397
1/8=9.834
1/4=15.097
can any1 tell me where i should improve in to hit 14..
Old Nov 20, 2005 | 09:12 AM
Bserieskllr's Avatar
well it would help if we knew what you had....car? engine? mods? tires?
Old Nov 20, 2005 | 09:24 AM
SD_Lurker's Avatar
HT White Ops
Default Re: 1st time @ track last night. (heyitzspikey)
your R/T is horrible. thats your numper 1 problem
Old Nov 20, 2005 | 09:31 AM
well i have a b16a obd1 i/h/e stage 1 clutch...well what is a good r/t time and what is r/t?
Old Nov 20, 2005 | 09:32 AM
Autoworks's Avatar
Default Re: (heyitzspikey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heyitzspikey &raquo;</TD></TR><TR><TD CLASS="quote">what is r/t?</TD></TR></TABLE>
reaction time
Old Nov 20, 2005 | 09:36 AM
dravesef's Avatar
what i think you need to do is get a better 60 foot and a better rt and you will see a better time
dravesef's Avatar
by the way what was your mph
Old Nov 20, 2005 | 09:50 AM
my mph was 93.32 for the 1/4 and for the 1/8 it is 9.834 what time you think i will get if i have a good r/t and 60??
Old Nov 20, 2005 | 10:29 AM
swifty4u's Avatar
Default Re: 1st time @ track last night. (nicks_jdmstyle_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">your R/T is horrible. thats your numper 1 problem</TD></TR></TABLE>
Reaction time has absolutely nothinig to do with his time. They don't add that to your time.
Your number one problem is 60 foot. Get that to a solid 2.2 and your be hitting 14.8-9
Old Nov 20, 2005 | 10:34 AM
how can i do that try launching better?
Old Nov 20, 2005 | 10:36 AM
swifty4u's Avatar
Yea..I'm guessing your spinning a lil too much? If you can, try slipping the clutch, or just launching lower.
Old Nov 20, 2005 | 10:40 AM
what would you launch at?
Old Nov 20, 2005 | 10:45 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heyitzspikey &raquo;</TD></TR><TR><TD CLASS="quote">what would you launch at?</TD></TR></TABLE>
All depends on the car, tires, track conditions, driving habits, etc.
I got my ECU chipped and I use a 2-step rev limiter, so this allows me to set my launch consistently for every run. If I set it too high, the car spins and gets an *** 60', like you did. If it's too low, the car bogs and runs slow. With my tires and setup, I found that I launch best at about 4000 RPM, but I also have very sticky street tires.
Bottom line is: You just have to experiment with it, and see what works with your setup. I'm hitting 2.1 60's myself, but an ideal goal for you would be 2.2's. Do that and you should see a 14.8 or so.
swifty4u's Avatar
I honostly wouldnt be able to tell you..what did u launch at when you ran the 15.09? Did u spin? If so..just drop it by 500 rpms
Old Nov 20, 2005 | 10:50 AM
phan's Avatar
Default Re: (swifty4u)
experiment with different launches. i found that my r/t's were best when launching at 5k RPM and feathering until i felt the tires hook. i'd run consistent 14.5's, trapping 97mph at best, and hitting numerous 2.1 60 ft. this was all with a stock b16, i/h/e and zdyne chipped ecu.
Old Nov 20, 2005 | 01:31 PM
Stunna MIKE's Avatar
I hit a 10.3 @ Irwindale Speedway, Which is only 1/8 of a mile. But I have A Stock D16a6 In My EF.
Old Nov 20, 2005 | 01:45 PM
s10cky's Avatar
yea r/t time has nothing to do with it. thats why its called an e/t for elapsed time. it starts as soon as you leave. you can tell by sitting there for 3 minutes and then going and still running a 15.0. someone might get mad at you though. haha
Old Nov 20, 2005 | 03:20 PM
Markb16a's Avatar
i launch at 5 grand and I got a stock b16a and I run like 14. something but that was a long time ago and now I got a 93 gsr so I should be like 13. something now but when u launch launch at the two yellow lights that count down before green u will do way better thats what I do but thats a secret not anymore though lata.
Old Nov 20, 2005 | 03:27 PM
phan's Avatar
Default Re: (Markb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a &raquo;</TD></TR><TR><TD CLASS="quote">i launch at 5 grand and I got a stock b16a and I run like 14. something but that was a long time ago and now I got a 93 gsr so I should be like 13. something now but when u launch launch at the two yellow lights that count down before green u will do way better thats what I do but thats a secret not anymore though lata.</TD></TR></TABLE>
are you serious? going from a b16 to a b17 is NOT going to take more than (at least in your case) half a second off your ET. do way better if he launches at "two yellow lights?" uh, did you or did you not read about the RT having nothing to do with ET?
Old Nov 20, 2005 | 03:56 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (phan)
2.3= suck.
clean that up with practice *only way to get better*
you'll be in 14s no prob
Old Nov 20, 2005 | 05:18 PM
crxvtecred's Avatar
Default Re: (Ace$nyper)
Your R/T has nothing to do with your 1/4 mile time. Your 1/4 mile time doesn't start until your over the R/T line. Your car is running pretty much what it should. Getting LSD will help get your 60 ft time down.
SacrificeTheory
Honda Civic (2006 - 2015)
10
Mar 12, 2007 11:18 PM
rollagti
Mar 24, 2006 08:21 AM
TurbodCX
Jun 17, 2004 06:11 AM
bboynekro
Feb 20, 2004 07:45 PM
g5r
Jun 14, 2003 09:12 AM
