what the hells wrong with my car now
Old Nov 20, 2005 | 04:06 AM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default what the hells wrong with my car now
okay so now my car, i installed the turbo timer.. it was fine after that, now when i'm at high rpm, the brake light flickers and ****, the car is getting a shakey most of the time, and when i pull the ebrake up. the brake light doesn't come on....also when i go to shift my rpm's down fall down as much as i think they should, and my clutch feels kinda weak for a stage 3...
i don't know any other way to put it..
but hopefully someone can take what i said and help me out.
Old Nov 21, 2005 | 10:47 AM
jdmcars.com's Avatar
Default Re: what the hells wrong with my car now (iHOPEyouCHOKE)
Your brake light doesn't come on when you pull up the brake? Have you checked the ground?
Did you install the Turbo Timer yourself? Most of them that I have installed, you need to tap into the ebrake wire -and maybe check were they or you tapped that wire out, sounds like it was simply disconnected.
Old Nov 21, 2005 | 11:59 AM
AbitAvenger's Avatar
description of motor setup and tuning, turbo timer, and how u wired it might help
Old Nov 21, 2005 | 12:01 PM
* B A N N E D *
Default Re: what the hells wrong with my car now (jdmcars.com)
TSR Performance did the install, JDMCars.. i might know you?
montrealracing
Honda Civic (2001 - 2005)
Apr 9, 2008 07:53 AM
iHOPEyouCHOKE
Nov 21, 2005 08:07 PM
shadow_ridge
Aug 11, 2005 10:35 PM
BlackThorN
Dec 6, 2003 12:58 PM
