Very annoying noise....
Old Nov 19, 2005 | 02:44 PM
mike001's Avatar
Default Very annoying noise....
My front-left wheel is making very annoying weird noise when i go 30 or more miles per hour. When i press the brakes lightly it stops. When i press gas peddle i hear that stupid annoying noise again. Should i change my brake pads or ?. I have accord 4 dr lx. Please help. tnx
Old Nov 19, 2005 | 02:49 PM
P_Adams's Avatar
Default Re: Very annoying noise.... (mike001)
That "Stupid" little brake noise is one of two possible things
1) Brake Pad wear sensors are scraping against the rotor
2) Rock is jammed between Brake Rotor and rear splash shield
P
Old Nov 19, 2005 | 04:17 PM
HondaMike17's Avatar
Default Re: Very annoying noise.... (P_Adams)
describe the noise, each of those 2 noises cause 2 different sounds, please give us more info on this noise besides it being annoying
Old Nov 19, 2005 | 11:57 PM
isquishplatano's Avatar
my freinds 3000gt had a bent splash shield cover. the sheet metal that goes behind the rotor. it was bent onto the rotor. so it made kind of a clanking noise. we took his tire off. banged it back with a hammer. hasnt been a problem since then.
or it could be a rock wedged between the splash sheild. like p adams says.
if its a loud annoying humming noise. it could be your hub that needs changing. it only appears after a certain mph. and it gets louder the faster your driving. i think its caused my messed up bearings in the hub.
Old Nov 20, 2005 | 06:50 AM
mad-ass's Avatar
brake squealers are going off. change them.
HC4
Honda CR-V & Element
Jul 4, 2019 05:45 AM
jns5209
Honda Civic (2006 - 2015)
Sep 8, 2017 03:49 AM
lazychina
Aug 20, 2008 05:45 PM
