enough oil supply to turbo?
Old Nov 19, 2005 | 01:06 PM
SpoolnByYou's Avatar
Default enough oil supply to turbo?
sup guys,
my turbo is a garrett turbo and the oil feed is made for a 1/4"th male piece. but my oil line kit came with a steel line with 1/8"th female ends,and a 1/8"th elbo. so i went and got a 1/4"th-1/8"th reducer and im running the 1/8"th elbo on it. will i be fine running the 1/8"th elbo like the kit came with,or is it to small to get enough oil to the turbo?
Old Nov 19, 2005 | 03:13 PM
stealthmode62's Avatar
Default Re: enough oil supply to turbo? (SpoolnByYou)
You're good.
Old Dec 11, 2005 | 02:28 PM
InfamousDC2FI's Avatar
Default Re: enough oil supply to turbo? (stealthmode62)
there are also people that run orfices (inline restrictors) to restrict oil pressure to there turbos so that they dont blow the seals. I believe that a lot of turbos are only meant to see 25-30 psi of oil pressure (please correct me if im wrong), where as our hondas are putting out twice that.
Old Dec 11, 2005 | 02:40 PM
wenlyone's Avatar
You should be good with 1/8th. call up garret and find out what is the max and min pressure spec for that turbo.
4tika4
Mar 28, 2012 04:41 AM
94TurboGSR
Sep 3, 2003 05:30 PM
SpyLude92
Feb 15, 2003 02:04 PM
filetofit
Sep 5, 2002 09:26 PM
Ri5e
Jun 20, 2002 10:41 AM
