Camber upgrade
Old Nov 19, 2005 | 10:43 AM
ImXposed's Avatar
Needs $$ for a Hooker
Default Camber upgrade
I'm thinking about getting a nicer camber setup, and I was wondering if anyone knew the differences between the stock LS camber setup and the ITR camber setup. If any body knows the differences between the two setups, that would be great. Also, if you have any suggestions for different brands please let me know. Thanks in advance.
Old Nov 19, 2005 | 11:11 AM
Padawan's Avatar
Darth ModerVader
Default Re: Camber upgrade (ImXposed)
What exactly is a "camber setup"?
Old Nov 19, 2005 | 11:33 AM
ImXposed's Avatar
the camber arms, sorry, I didn't know exactly what they were called. Sorry to be so vague.
Old Nov 19, 2005 | 11:45 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (ImXposed)
Well everyone has their favorites, I know a lot of people use SPC. Omni-Power ones are alright, as long as they have been the redesigned ones, and Skunk2 ones are good, but you have to loctite the bolts or it will slide around. The choice is yours.
Old Nov 19, 2005 | 11:47 AM
evilempire's Avatar
type r front UCA part #: 51450-ST7-020
ls front UCA part #: 51450-ST7-020
Get where I'm going with this?
Old Nov 19, 2005 | 12:45 PM
ImXposed's Avatar
Default Re: (evilempire)
yup... same... so no point really. Thanks, exactly what I needed to know.. I think I'll keep looking.
Old Nov 19, 2005 | 01:27 PM
Padawan's Avatar
Darth ModerVader
What in particular are you trying to achieve? If you can explain your goals, it might be easier to help you out.
Old Nov 19, 2005 | 01:30 PM
ImXposed's Avatar
Default Re: (Padawan)
i'm planning on dropping my car a few inches in the next couple weeks, and I am trying to find a suitable solution to negative camber wear. I would prefer to be able to adjust the camber.
Old Nov 19, 2005 | 01:36 PM
Padawan's Avatar
Darth ModerVader
Okay, that's much clearer. Many people are going to suggest to you that adjustable camber (either arms or some form of kit) is not going to be necessary, depending upon how low you go. In many cases, simply having the car aligned with the toe properly adjusted will eliminate the majority of tire wear problems.
Old Nov 19, 2005 | 03:33 PM
ImXposed's Avatar
awesome... is it difficult with the right equipment to align a car yourself, or is it really just not worth the hassle?
Old Nov 19, 2005 | 07:11 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImXposed &raquo;</TD></TR><TR><TD CLASS="quote">awesome... is it difficult with the right equipment to align a car yourself, or is it really just not worth the hassle? </TD></TR></TABLE>
It's difficult, if not impossible, to get the alignment within the tolerances that a competent shop with the proper equipment could accomplish. A professional job is not very expensive, and you'll be assured it is done correctly.
MrSalenga
Suspension & Brakes
Dec 3, 2009 05:38 PM
kndaqikEG
Feb 20, 2005 05:42 PM
Bull
Feb 12, 2004 02:47 PM
SMZ GSR
Oct 16, 2002 02:24 PM
02WRX
Jul 24, 2001 01:27 PM
