Help! How do I push back the caliper piston on my rear rotor???
I have a 92 SI w/ rear discs and when I was swapping out the pads for new ones I can't seem to get the caliper piston to push back far enough to clear the new pads. Do I need to bleed the fuel lines?? I didn't have my emergency brake on or anything but I can't seem to get them back.
thanx
thanx
this is correct you need to go rent a tool from a parts store that spins as it compresses it will come with many different dies to use just make sure you have the right 1 in place and your set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkhour Racing »</TD></TR><TR><TD CLASS="quote">I have a 92 SI w/ rear discs and when I was swapping out the pads for new ones I can't seem to get the caliper piston to push back far enough to clear the new pads. Do I need to bleed the fuel lines?? I didn't have my emergency brake on or anything but I can't seem to get them back.
thanx</TD></TR></TABLE>
I just can't help but ask what the fuel lines have to do with the brakes? The rear calipers on many vehicles are "threaded".. so you need to rotate the piston clockwise to get it to compress. I certainly hope you weren't going to town with any type of a clamp on it.
The fronts you can compress with a c clamp. the rear are different. You dont need to rent a tool, just get a screwdriver or if you have something that will work better then use that, but all you do it just twist them.
yeah. that is what the x grove is for on the piston. You don't need any special tools. Just a screw driver and a c clamp or big adjustable wrench.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3_South »</TD></TR><TR><TD CLASS="quote">I use a C clamp. Makes it easier than having to bleed.</TD></TR></TABLE>
yeah you wonna buy him a caliper after he does that???
If you don't wonna buy the the tool, get some needle nose pliers and spin it in clockwise. Make sure that the pin on the pad matches up with a piston (aka make sure that the pad sits flush).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">yeah. that is what the x grove is for on the piston. You don't need any special tools. Just a screw driver and a c clamp or big adjustable wrench.</TD></TR></TABLE>
Man, will you guys just forget the damn clamps for the rear brakes.... please?
Kevin Nealis
Apr 19, 2015 07:53 PM
BB4lude
Feb 11, 2008 01:47 PM
jadmEM1
Jun 7, 2007 06:05 PM
