rattling after omni test pipe
Old Nov 19, 2005 | 01:05 AM
ITB
Guest
Posts: n/a
Default rattling after omni test pipe
aight it rattles. either my bolts or loose or two of the test pipe peices are hitting each other. after I installed it i felt air coming out between the first and second peice of the test pipe. anyone else have this problem? I hope its normal with the omni test pipe cuz I'm lazy to jack up the car and tighten the bolts, etc etc
Old Nov 19, 2005 | 03:09 AM
Circuit Star-29's Avatar
Default Re: rattling after omni test pipe (ITB)
Don't you have to get it welded? Or clamp it? If not, did you check the heat shields?
Old Nov 19, 2005 | 03:29 AM
XstouterX's Avatar
Default Re: rattling after omni test pipe (C-speed racer)
do u jus thave straight bolts in there? or do u have the spring bolts? if u dont have the spring bolts...after u tighten them down very shortly after the straight bolts will start to walk because of the insane torque a honda puts down ahah...
Old Nov 19, 2005 | 05:16 PM
ITB
Guest
Posts: n/a
well the top bolt was loose and i tighten it and it and still rattle. turns out it was the o2 sensor wasnt tight enough, hehe
Old Nov 19, 2005 | 08:52 PM
Integra21's Avatar
Default Re: (ITB)
i have an Omni test pipe and i called Omni and they said it doesnt require welding, that the carbon build up will be enough to seal it. i had mine TIG welded though
no rattles with the spring bolts
Old Nov 20, 2005 | 06:14 PM
ITB
Guest
Posts: n/a
Default Re: (Integra21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">i have an Omni test pipe and i called Omni and they said it doesnt require welding, that the carbon build up will be enough to seal it. i had mine TIG welded though
no rattles with the spring bolts </TD></TR></TABLE>
the whole point of omni pipe is universal for all exhaust set ups. once you weld it then it can only be for that specific car..
Old Nov 20, 2005 | 07:22 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITB &raquo;</TD></TR><TR><TD CLASS="quote"> I'm lazy to jack up the car and tighten the bolts, etc etc</TD></TR></TABLE>
WTF... maybe you should do that first, or not work on cars at all.
95whitegizzer
Jun 20, 2006 11:27 AM
wreckedagain
Dec 11, 2001 11:16 PM
blktyper2001
Oct 20, 2001 11:53 PM
Toda Party
Jul 7, 2001 03:09 AM
