Looking for close up pics of the Nuformz rear suspension kit
Old Nov 18, 2005 | 09:24 PM
SRDrag's Avatar
Default Looking for close up pics of the Nuformz rear suspension kit
All Ive seen are pics from a distance. I was curious if anyone had any close up pics of the kit?
Old Nov 18, 2005 | 09:51 PM
tony1's Avatar
Default Re: Looking for close up pics of the Nuformz rear suspension kit (RIGHTHANDDRIVEITR)
I don't have any pics, but i've worked with it before. Is there something in particular you want to know?
Old Nov 19, 2005 | 10:27 PM
IMALLSLO's Avatar
94 Civic
As big as I have.
This was prototype and was the second one he made. I have no idea if anything has changed in the last 4 years since this pic was taken. Hope this helps.
Old Nov 20, 2005 | 12:37 PM
SRDrag's Avatar
Default Re: Looking for close up pics of the Nuformz rear suspension kit (IMALLSLO)
Thanks for the pic. You wouldnt happen to have a pic of the back side of the spindle would you? Im curious as to how the control arms and trailing arms adapt to the spindle. From what Ive seen, the Lamb and Strange spindles have 1 mounting location below (for the LCA) and one on the steering arm. Looking at the Nuformz kit, I see there are a total of 3 arms. Is there a custom bracket mounted on the spindle for the 3rd (trailing arm) bar? Or, is the trailing arm mounted on the LCA??
Old Nov 20, 2005 | 01:33 PM
bigTom's Avatar
u can either use a spherical bearing in a "cup" as seen in the picture above n weld both tubes to that or you can use a piece that strange sells... it also has a spherical bearing but has a nice attactchment for another arm to come off of it... my description probably sucks as you just really need to see it. if you have strange catalog look in that... ull find it
Old Nov 20, 2005 | 02:03 PM
six sigma racing's Avatar
Default Re: Looking for close up pics of the Nuformz rear suspension kit (bigTom)
here is the strange kits layed out.. If you buy the strange kit it will come with a lower spherical bearing that has clevis joint built in to it so you can run a control arm support...Or like Big Tom said you can run a blank Spherical bearing and weld your own control arms to it... Here is two pictures of both.. I used the complete strange kit in the rear of my own car and had a blank spherical ball joint to make custom front arms.. They both share the same lower Bearing ID for the same size shaft...
b00st4life
May 14, 2019 07:19 AM
.brad
Suspension & Brakes
Jul 22, 2009 10:36 AM
hovic
Suspension & Brakes
Dec 7, 2007 11:32 PM
SpoogenJay
Mar 14, 2007 10:38 PM
