stock rim size?
ok what is the stock rim size and bolt pattern? i been told different numbers and not sure what the real size is. i was told it's 15x6 50 offset 5x114 and 15x7 45 offset and 5x114.3. which is the right one?
i did a search and this was what i got out of it. need to know what is right.
what are some good light rims i can use to put some drag tires and slicks on and where can i get it from?
see again, is it 45 or 50mm off set. i'm tring to find some rims for drag wheels and what to get the exact size to avoid any clearance problems. and the shop i'm getting it from whats to know the infor so they can get me the right ones.
5x114.3, 15x6, +50mm offset, 15.6 lbs, Cast
