11" front brake upgrade question (searched)
I ordered in my new calipers for my brake upgrade from O'Reillys the other day and when I went into pick them up today I was dissapointed to find that I had single piston calipers and not dual pistons calipers. I had ordered them for a 98 accord, I was under the impression that these would be dual caliper but I guess I was wrong. Can someone tell me exactly what year and what model I need to order calipers for in order to get the dual pistons calipers? The car is a 94 del sol S with Integra knuckles waiting for it.
lol ..the only dual caliper system comes from the legend GS coupe. best place to find that would have to be a junkyard unless that place can actually get them remanufactured.
Munkyw3rkz.webs.com
u guys mean dual piston not caliper...
teh 94-95 legend S calipers are teh same as teh 91-96 NSX but the NSX are lighter adn have the NSX name bling on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake »</TD></TR><TR><TD CLASS="quote">u guys mean dual piston not caliper...
teh 94-95 legend S calipers are teh same as teh 91-96 NSX but the NSX are lighter adn have the NSX name bling on it</TD></TR></TABLE>
and the aluminium cooling fins
so all I need is the 94-95 legend S calipers....I figure they'll be cheaper and easier to find than NSX calipers. And those will bolt up to the 94+ Integra knuckles right?
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunksol »</TD></TR><TR><TD CLASS="quote">so all I need is the 94-95 legend S calipers....I figure they'll be cheaper and easier to find than NSX calipers. And those will bolt up to the 94+ Integra knuckles right?</TD></TR></TABLE>
legend GS......
yes they will use a ITR or Legend rotor but drilled for 4x100...
if u use the ITR rotor which is 23mm in thickness u will need to trim the back side of teh caliper theres a slight lip that need grinding down.
if u use Legend rotors then you can get away without grinding the caliper......
i had them front and back
legend GS......
