What's not stock about this engine
Old Nov 18, 2005 | 02:44 PM
RGoose18's Avatar
Default What's not stock about this engine
Modified by RGoose18 at 3:18 AM 11/19/2005
Old Nov 18, 2005 | 02:48 PM
tequilakid's Avatar
Default Re: What's not stock about this engine (RGoose18)
What's the red and black wires running over the drivers shock tower?
Old Nov 18, 2005 | 02:50 PM
RGoose18's Avatar
Default Re: What's not stock about this engine (tequilakid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tequilakid &raquo;</TD></TR><TR><TD CLASS="quote">What's the red and black wires running over the drivers shock tower?</TD></TR></TABLE>
Maybe alarm wiring????
Old Nov 18, 2005 | 02:54 PM
Mythias's Avatar
Washer fluid hose.
white rocket's Avatar
Those look like the tubes for washer fluid delivery to the windshield. The rad cap doesn't look OEM ITR so maybe the rad isn't either. Red hose for overflow. MSD blaster coil under CAI. VIN plate on tranny
That's all I can see.
Krakhor9's Avatar
New User
or old stereo wiring
Old Nov 18, 2005 | 02:55 PM
IGGY's Avatar
The Intake, the header, the red hose for the radiator resivoir, the two boxes next to the power steering fluid, the red valve cover and possibly the entire engine.
Old Nov 18, 2005 | 02:56 PM
RGoose18's Avatar
Default Re: (IGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">The Intake, the header, the red hose for the radiator resivoir, the two boxes next to the power steering fluid, the red valve cover and possibly the entire engine.</TD></TR></TABLE>
haha......let's be optimistic here
Does that look like epoxy or some similar substance near the driver side shock tower?? Anyone have any ideas what that could be?
Old Nov 18, 2005 | 03:08 PM
Ooo...Ooo....I see aftermarket suspension too
Not sure about the epoxy. This picture doesn't do it justice.
FYI - I was looking at a 2005 Ford F-150 SuperCrew today with a 12K hit on it. Drivers side T-bone accident. Damaged has been fixed. I crawled around that sucker and had a hard time spotting any imperfections. Some major hits can be fixed properly.
Old Nov 18, 2005 | 03:38 PM
omiehomie's Avatar
it that one of the R's in copart? i saw that one too! but i asked my dad about it and he told me that if the car has a salvage title on it, and it has slight visible damage on the outside, the underbody of the car (frame and other components) is probably all f-ed up, and thats why they salvaged the caR.
Old Nov 18, 2005 | 03:56 PM
RGoose18's Avatar
Default Re: What's not stock about this engine (omiehomie)
What's copart? a website? Never heard of it before
Modified by RGoose18 at 1:27 AM 11/19/2005
Old Nov 18, 2005 | 04:16 PM
98 Spec R's Avatar
I bet the front core support has been changed. None of the OEM stickers are on it. You should check the frame rails for bends ore kinks.
Old Nov 18, 2005 | 04:19 PM
RGoose18's Avatar
Default Re: What's not stock about this engine (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">I bet the front core support has been changed. None of the OEM stickers are on it. You should check the frame rails for bends ore kinks.</TD></TR></TABLE>
Aren't the core supports on all USDM to JDM conversion changed?? Also Which stickers are you talking about. Thx
Old Nov 18, 2005 | 04:48 PM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">
Aren't the core supports on all USDM to JDM conversion changed?? </TD></TR></TABLE>
I didnt realize it had a JDM front End from the pic you posted.
Old Nov 18, 2005 | 04:51 PM
RGoose18's Avatar
It doesn't it's USDM, I'm just stating that it's not a big deal if the core support is changed, ppl do it everyday when they do a JDM conversion
Old Nov 18, 2005 | 05:03 PM
98 Spec R's Avatar
It doesn't it's USDM, I'm just stating that it's not a big deal if the core support is changed, ppl do it everyday when they do a JDM conversion</TD></TR></TABLE>
That means it has been hit hard enough to have to replace the core support. I wouldnt want an ITR that has had the core replaced due to an accident. IMO.
Old Nov 18, 2005 | 05:38 PM
XyKo
Guest
Posts: n/a
the guy is selling this car for $10K with 10K miles.
jeremy.
Oct 21, 2008 08:38 PM
jdmomar
Apr 9, 2007 07:28 PM
REDLINEtypeR
Mar 5, 2007 05:26 AM
ATS*VEEE
Northern California (Sales)
59
May 24, 2006 04:52 PM
type_r_jon
Feb 13, 2006 06:44 AM
