car won't start
alright my 91 acccord will not start....I have determined it is not getting any fuel.....it is not throwing any codes I jumped the ecu and it showed a solid check engine light. I am pretty sure fuel pump is shot can anyone else give me some input thanx
Casey
BTW it has a full tank of gas
Casey
Could be fuel pump or main relay. Get in the car and get someone else to stand by the gas cap with it off. turn the key to second position the fuel pump should prime for two seconds. You should be able to hear it (the pump is in the tank). If you don't check main relay first then fuel pump. Taking the tank down is a bitch, and you would deffinatly have to drain it first. You should do a search for relay information. (where to find and how to fix)
