What should i do to my GSR HATCH?
Old Nov 18, 2005 | 11:27 AM
misternguyen's Avatar
Default What should i do to my GSR HATCH?
hey i got a gsr hatch, but i'm unsure of what mods to do to the motor? right now i have a dc header 4 into 1, intake (not sure what brand), and thats about it. i wanted to do build my motor up but not sure what to do yet. any suggestions on what parts to buy and install? lmk thanx
Old Nov 18, 2005 | 11:32 AM
Slow EJ8's Avatar
Default Re: What should i do to my GSR HATCH? (misternguyen)
1. what is your budget?
2. what are your power goals?
3. NA or FI? (or doesnt it matter)
Start with the first question and answer them in order as they in some ways determine what you might decide for the question under it.
Old Nov 18, 2005 | 11:33 AM
any suggestions???? ttt
Old Nov 18, 2005 | 11:34 AM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misternguyen &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions???? ttt</TD></TR></TABLE>
yes, dont bump a thread after only 6 minutes lol... people will see it, give them time. Read my suggestions questions above and post your answers to them
Old Nov 18, 2005 | 11:35 AM
budget is whatever i can come up with. i have a steady job now but i dont want to go to extreme and buy all the top of the line items. and my power goal, run a low 13. i want an all motor car. thanx slow ej8
Old Nov 18, 2005 | 11:43 AM
Slow EJ8's Avatar
I am not too familier with the GSR motor and how much NA build up potential it has. Not saying it doesnt but I am not familier with it. Have you run the 1/4 mile in the form that it is in now?
To add to the NA build you have now add in some cams, maybe a new intake manifold, and some type of engine managment (of course a tune with that). Also noticed you didnt have an exhaust already, you could add one of those. Like I said I dont have much knowledge about the GSR motor so hopefully others will be able to jump in and help out.
Old Nov 18, 2005 | 11:44 AM
Hercules's Avatar
First buy a skunk2 or blox intake manifold off ebay and rechip your ecu.
Old Nov 18, 2005 | 11:48 AM
yeah i was alraedy thinking about purchasing the skunk2 intake manifold. but didnt think about chipping my ecu. what do you recommend on chipping it???
Old Nov 18, 2005 | 04:52 PM
1995Civic's Avatar
Default Re: What should i do to my GSR HATCH? (Hercules)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hercules &raquo;</TD></TR><TR><TD CLASS="quote">First buy a skunk2 or blox intake manifold off ebay and rechip your ecu.</TD></TR></TABLE>
The Skunk2 IM has some issues on matching up correctly. What would chipping his ecu do for him?
If you're looking to go all motor, you can start with a J's Racing Intake (carbon fiber) aka "Whale's *****" and you can stick w/ that DC 4-1 header for upgraded power in the upper RPM band. Also, I personally like the Apex'i N1 exhaust. If you're a big time spender, you can always spring for some ITB's
Old Nov 18, 2005 | 05:50 PM
Hercules's Avatar
Default Re: What should i do to my GSR HATCH? (1995Civic)
you need to rechip the gsr ecu to run like a itr or b16a single plane manifold w/o the butterflies and so vtec kicks in at the right rpm.
Old Nov 18, 2005 | 06:33 PM
vc's Avatar
vc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misternguyen &raquo;</TD></TR><TR><TD CLASS="quote">budget is whatever i can come up with. i have a steady job now but i dont want to go to extreme and buy all the top of the line items. and my power goal, run a low 13. i want an all motor car. thanx slow ej8</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1435973
Heres what I have.. I thikn I should be able to run low 13s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">The Skunk2 IM has some issues on matching up correctly.</TD></TR></TABLE>
I've heard that alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">If you're looking to go all motor, you can start with a J's Racing Intake (carbon fiber) aka "Whale's *****" </TD></TR></TABLE>
I need one of those =D
btw, do you have a eg or ek?? and what model??
Old Nov 18, 2005 | 07:00 PM
VTAKKK!!'s Avatar
i personally went with the intake mani from professional products. AEBS designed it with Honda to work amazing with vtec. i have never heard a bad review of it and it matches up perfect. no problems and it looks nice.
check it out http://cgi.ebay.com/ebaymotors...QrdZ1
Old Nov 18, 2005 | 07:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (VTAKKK!!)
Here. You want to know how to pull low 13's in a GSR hatch? You have two options
<u>Option A.</u>
1.) drag slicks. If you want to run 13's NA without completely rebuilding your engine, you want drag slicks.
2.) valvetrain upgrade and big cams coupled with an appropriate intake manifold and adjustable cam gears. A better header and a true 2.5 inch exhaust will help significantly as well.
3.) Hondata tuning on a dyno including wideband readings.
<u>Option B.</u>
1.) drag radials. These are not slicks: they can be run on the street, are much cheaper and give you a substantial portion of true-slick performance.
2.) 85 shot of Nitrous Oxide.
Old Nov 18, 2005 | 07:38 PM
EJ7's Avatar
EJ7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misternguyen &raquo;</TD></TR><TR><TD CLASS="quote">hey i got a gsr hatch, but i'm unsure of what mods to do to the motor? right now i have a dc header 4 into 1, intake (not sure what brand), and thats about it. i wanted to do build my motor up but not sure what to do yet. any suggestions on what parts to buy and install? lmk thanx</TD></TR></TABLE>
If you have another car(daily driver) you could send the head to DPR for a stage 6 head job.
Check out http://www.dprracing.com
Old Nov 18, 2005 | 11:43 PM
TsukubaDreams's Avatar
what year hatch are your running it in??? Slicks will drop your times easily... some hondata tuning, and b16a pistons, balance crank and rods, type-r valves, skunk 2 stage ll cams, valve springs, retainers, whales *****, exaust
but dont forget the free stuff............................................. weight reduction succas... gut your **** out... good luck and keep us updated on what you plan on doing.
Old Nov 19, 2005 | 02:17 AM
r3mix1's Avatar
why go n/a? turbo makes a lot more sense.
Old Nov 19, 2005 | 02:19 AM
Fatchance187's Avatar
Default Re: (r3mix1)
Ask the Teg forum noob
Old Nov 19, 2005 | 02:56 AM
vc's Avatar
vc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3mix1 &raquo;</TD></TR><TR><TD CLASS="quote">why go n/a? turbo makes a lot more sense.</TD></TR></TABLE>
what a way to start ur first post. welcome to ht. anyway.. some people like the NA feel rather the Turbo feel..
Old Nov 19, 2005 | 03:42 AM
littlegreenb18's Avatar
Default Re: What should i do to my GSR HATCH? (vc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1435973
Heres what I have.. I thikn I should be able to run low 13s.</TD></TR></TABLE>
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 &raquo;</TD></TR><TR><TD CLASS="quote">Ask the Teg forum noob</TD></TR></TABLE>
shut up
to the op, i think a lot of people have over the top expectations of gsr hatches, i know i did. i have a skunk mani, stock p72() 4-1 2.5 collector header, 2.5in catback and aem cold air. and i did 14.4, do be fair my launches sucked, i had all season tires, and the stock p72 dosn't work well with my setup(got a chipped p28 waiting for dyno tune now). but i really expected it to be faster. If i were you, i'd get some easier to attain goals, and take it step by step, dyno it, and take it to the track, and figure out what you need and take it step by step, it always seems to work better that way
Old Nov 20, 2005 | 12:35 PM
vc's Avatar
vc
Default Re: What should i do to my GSR HATCH? (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">no
why not??
Old Nov 20, 2005 | 02:02 PM
typeoneeg6's Avatar
i would do a set of cams, intake mani, cam gears, valvesprings, retainers, maybe thinner headgasket to bump up compression a little bit(unless you just wanna get new pistons and rods, then i would do a stroker kit).
itb's are expensive and require extensive knowlegde to tune correctly as well as programmable engine management which can also be very expensive.
but hondata s300 is somewhat affordable and looks to be a viable option.
good luck with your motor man.
Old Nov 21, 2005 | 07:58 AM
Default Re: What should i do to my GSR HATCH? (typeoneeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeoneeg6 &raquo;</TD></TR><TR><TD CLASS="quote">but hondata s300 is somewhat affordable and looks to be a viable option.</TD></TR></TABLE>
dont think his car is quite at the stage of needing a s300... a s200 will do you great and you still have more room to build on it. mabey even an s100 depending on what your end goal is
Old Nov 21, 2005 | 07:59 AM
Slow EJ8's Avatar
Default Re: What should i do to my GSR HATCH? (TsukubaDreams)
woot i made it into a sig!
lol
Old Nov 21, 2005 | 08:01 AM
TehMan's Avatar
Default Re: What should i do to my GSR HATCH? (Slow EJ8)
ITB's and run a motec system.
________
Bmw 803
Old Nov 21, 2005 | 09:32 AM
Honda Bull's Avatar
Default Re: What should i do to my GSR HATCH? (TurboEJ2)
Blox/Skunk2/AEBs manifold, ITR cams and tune it. Borrow slicks from someone and find a good track. Low 13s...
