Just finished cam install, PROBLEMS< PLEASE help!!!
Old Mar 11, 2002 | 08:24 PM
nfn15037's Avatar
Default Just finished cam install, PROBLEMS< PLEASE help!!!
OK, this is a non-ITR related question, so Vegeta or Ross, dont read this Anyways, i just finished installing ITR cams in a GSR, and its running like ****. It idles at like 400 RPMS and it has ZERO throttle response. Its almost like its not getting spark. Its really sluggish at first, but picks up around 7k, but not very hard. It is definately slower. I checked the timing belt, doesnt seem to be a tooth off or anything. Any other suggestions? I have never seen anything like this, so any help would be greatly appreciated!
Old Mar 11, 2002 | 09:27 PM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS< PLEASE help!!! (nfn15037)
ttt, please help
Old Mar 11, 2002 | 09:30 PM
Type-Rare#1248's Avatar
anything to do with cam gears??
Old Mar 11, 2002 | 09:40 PM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS< PLEASE help!!! (Type-Rare#1248)
Thats what im thinking, but everything seems to be in order with the timing belt. Maybe i got the belt off 1 tooth on the crank end, guess ill re-check everything tomorrow. It seems more spark or fuel to me than anything else. Do you think the GSR computer would run the cams OK? Theyre not that much bigger than GSR cams. I dont know, but im gonna keep looking
Old Mar 11, 2002 | 09:49 PM
Pinhead's Avatar
New User
well If you need a ecu I'll sell you mine....actually if you can get me a chipped p28ecu I'll give you mine for it DOH i forgot your obd1 lol nm
Old Mar 12, 2002 | 08:40 AM
The Toecutter's Avatar
check cam timing. ITR cams run fine in a GSR. You may have slipped the timing belt a tooth or two off on the crank end. I would take the cams off, put piston #1 at TDC and put the cams on with the cams at top dead center and slip the belt on and re-tension the belt. Better to be safe than sorry.
Old Mar 12, 2002 | 08:43 AM
owen_the_soyboy's Avatar
are you sure you are using the correct tdc mark on the crank?
there are three marks close ot one another, then a fourth is an inch or so away, use that one, its your cylinder one TDC !
Old Mar 12, 2002 | 08:48 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Just finished cam install, PROBLEMS< PLEASE help!!! (owen_the_soyboy)
Or just stick a long object into the spark plug hole and rotate the crank until number 1 is at TDC
Old Mar 12, 2002 | 08:58 AM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS< PLEASE help!!! (Dominic Toretto)
Yeah, i couldnt figure out which mark to use on the crank pulley, so i stuck a long screwdriver in the cylinder thorugh the sparkplug hole so i could figure out which mark was the right one. I still cant figure out WTF is wrong, but im going to pull it all apart today
Old Mar 12, 2002 | 09:01 AM
Austin's Avatar
I once saw a shop doing that and I was WTF are they doing? Then I was , now I understand.
Old Mar 12, 2002 | 01:34 PM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (Austin)
TTT, any other suggestions??
Old Mar 12, 2002 | 02:06 PM
GZR4DR's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (nfn15037)
Obviously your cam timing is off. Set the crank pulley so the white mark lines up with the line on the timing belt cover. Then make sure your #1 piston is at TDC, and not BDC. Pull the #1 spark plug to check this. Next when you align the cams to TDC, make sure the marks on the edges of the gears line up with each other. Its at 9 oclock on the intake cam, and 3 oclock on the exhaust cam. You should be able to see the marks. Also there are 2 holes in the oil bars that you can use a allen key or something to see if the cams are indeed at TDC. If they are, the allen key will fit into the hole in the cam. You will understand what i mean when your working on it. Next make sure you do a valve adjustment. If they are way off, your car will idle like crap. Also when putting on the belt make sure you do the tensioner right, otherwise it may slip and you could bend all of your valves.
ITR cams are a direct drop in. It should not be hard at all if you know what your doing. I made 202whp on my GSR motor with ITR cams, so obviously they can work just fine. The cams are now in my B20-vtec.
Old Mar 12, 2002 | 03:32 PM
Dropspeed's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (GZR4DR)
I'm just going to agree with others its definetly cam timing. The cams will drop right in and the computer will run them just fine. When you double check you should find a problem somewhere, even havein the t-belt off by one tooth will cause a problem (I ,cough cough, speak from,!!!! experiance)
Mattj
Old Mar 12, 2002 | 04:27 PM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (Dropspeed)
Alright, thanks guys! Im going right now to fix it. On my stock camgears, they dont have the 2 white dots, just the "UP" on each one. Hopefully ill get this all sorted out and my Geeser will be freer-breathing by later tonight Again, thanks for all the help guys
Old Mar 12, 2002 | 04:53 PM
integratom's Avatar
No paint on the gears the white paint is on the crank pulley and to be sure you have cams level use a strait edge(ruler) across the gears all 4 marks should be level. theres also the locking holes through the cam holders to the cams but you need a nice fitting allen wrench or pin to lock them nice and level. Goodluck
Old Mar 12, 2002 | 05:07 PM
C-speed's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (integratom)
One thing to check.. make sure you put the plug wires back on correctly.. if you mixed those up, it'll cause the same symptoms easily overlooked
Old Mar 12, 2002 | 05:13 PM
b00st-0wnz's Avatar
THey do have "UP" but they will also have a little line on them. Exhaust 3 oclock and intake 9. As stated before
Old Mar 12, 2002 | 05:20 PM
jeff652's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (ATLnNCSuck)
Did you adjust the valves after?
Old Mar 12, 2002 | 10:16 PM
nfn15037's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (FL n NC rock j00)
Starnge, mine dont have the lines. Anyways, i couldnt fix it cause the guy whose garage i used, his compressor broke, and we didnt have anything long enough to break the crank pulley loose Hopefully tomorrow, i need to get to sebring thursday AM
Old Mar 14, 2002 | 12:15 PM
GZR4DR's Avatar
Um why would you need to pull the crank pulley off?!?!?!?! That makes no sense at all. Also do what the other guy stated. Check and make sure your plug wires are in right. Heres a ghetto diagram that should help. Pretend your on the passenger side of the car looking directly at the distributor.
34
12
That should help. Remember #1 cylinder is the crank pulley side. That should help. Also if need be just use stock gears, because yours might be off. My friend bought a set of aftermarket gears for cheap, and it turns out the marking were all off.
Old Mar 14, 2002 | 12:24 PM
Mike K's Avatar
bring it by Acura. if your valve cover is cut, i can tell you if the timing is off in like 2 seconds.
did you adjust your valves properly? if they're adjusted too tight, then the valves will always be *slightly* open and your car won't idle worth a ****.
PS- snap any more bolts?
Old Mar 14, 2002 | 06:02 PM
CW-ITR-329's Avatar
Default Re: Just finished cam install, PROBLEMS; PLEASE help!!! (Mike K)
He took it over to topspeed and they took care of him. His timing belt was off by a couple teeth, but it runs really nice now. BTW... Thanks Mike K for all the help with my car Ryan
Old Mar 14, 2002 | 06:19 PM
Nighthawk GS-R's Avatar
New User
woah...you dynoed 202 whp with just cams......what else do u have?? im curious
ok just read your sig....
[Modified by Nighthawk GS-R, 10:21 PM 3/14/2002]
Old Mar 14, 2002 | 06:58 PM
95GS-R's Avatar
How do you like the ITR cams? I have the intake cam in my GS-R and I love it.
To be perfectly honest tho I have had it in for so long I can't remember what it was like before.
VTEC is certainly louder now.
Old Mar 17, 2002 | 12:48 AM
nfn15037's Avatar
Heh, i got it all running OK now. No more bolt snappage mike, after talking to you i figured out how to do it right. I just got back from Sebring, so tomorrow ill adjust my valves and really beat on it Oh, and how i like tham, theyre really nice. The midrange is WAY better than the GSR cams, now i need a JUN II Intake cam
PS-thanks for the help Mike
skata89
Dec 19, 2006 09:03 AM
216.226.142.95:27016
Jun 28, 2003 05:55 PM
batboyvaj
Jul 22, 2002 07:53 PM
