Lowering Fuel Pressure.
Yes I searched and there is even no such topic. So I have the AEM one and want to lower the pressure on my mini me so i just turn the screw at the top?
If you lower the fuel pressure, then that means there will be less fuel being injected per injection event - is that what you're aiming for? Is yes, then lower the fuel pressure.
Will it make the car run better - I don't know, what's your setup?
I need less presure , yes i know LEan is MEAN but I need to pass emissions and I failed on Hydrocarbons which are unburned fuel, and in IL. they do not car bout the NOX so i should be good now!
