skunk2 dual valve springs... one spring "loose"??
Old Nov 18, 2005 | 06:16 AM
91civicDXdude's Avatar
Default skunk2 dual valve springs... one spring "loose"??
i have skunk2 valve springs and retainers in my b16a3, running comp 57200 .490/.450 lift 284/284 duration cams. the springs and retainers were bought brand new from skunk2 and professionally installed by a local head builder. I've put approximately 20,000 miles on the head since installation.
anyways, my concern is this... i recently did a valve lash adjustment, and i noticed that one valve spring on the intake side is "soft" in that i can push down on it.. none of the others are like this. I checked with a 'mirror on a stick' to see if maybe the inner spring was broken or something, which might explain the "softness" of the valve spring, but i did not see any cracks or anything broken.
obviously this isnt normal, and i need to replace it asap before a valve drops or something and ruins my engine. Does skunk2 sell just a single valve spring set (inner & outer)?? what would cause a spring to just go soft?
Old Nov 18, 2005 | 08:09 AM
I've read the archive posts of "Skunk2 valve train sucks", i just want to know what i can do short of buying a whole new set of springs & retainers...
on a side note, anybody happen to know the usable life of titanium retainers?
Old Nov 18, 2005 | 07:03 PM
i guess nobody has ever needed only one valve spring huh
Old Nov 19, 2005 | 03:14 AM
Runnerdown's Avatar
Default Re: (91civicDXdude)
How old are the springs? Skunk definitely had some issues with theirs in the past. Sounds like that spring is broken(maybe hard to see) or just fatigued badly. I would replace all of them not just one.
smnowell
82
Jan 24, 2011 11:52 PM
killerB16A
17
May 4, 2009 09:09 AM
b20vtech
Nov 6, 2006 09:54 PM
civic dx
37
May 4, 2005 10:58 AM
rcurry14
Aug 6, 2004 10:13 PM
