Help!!! Speedometer not working and lights dim in and out
I recently installed a jdm header. The car pops the check engine light. Now the speedometer is not working along with the cars headlights and interior lights dim in and out. I wanted to know if anyone has any idea what could cause all this. Is it because of the CE light? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Sounds like the front engine ground is missing. </TD></TR></TABLE>
Beat me to it.
Beat me to it.
These are the codes:
P0141 - Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
P1298 - Electric Load Detector (ELD) Circuit High Voltage
Check the underdash fuse labelled "Alternator SP Sensor." It should be fuse #15, 7.5A. It feeds all of the affected circuits. If it blows, it kills the alternator AND the alternator warning light. Seems like failure modes weren't thought out here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelly »</TD></TR><TR><TD CLASS="quote">Check the underdash fuse labelled "Alternator SP Sensor." It should be fuse #15, 7.5A. It feeds all of the affected circuits. If it blows, it kills the alternator AND the alternator warning light. Seems like failure modes weren't thought out here.</TD></TR></TABLE>
I checked the fuse and bingo...fuse blowned for alternator. Thanks guys for ur help and suggestions.
SB97civic
15
Jan 19, 2004 08:20 AM
detector, dim, electric, engine, headlights, honda, insight, light, lights, load, on, spedometer, speedometer, stopped, working
