Suspension & Brakes Theory, alignment, spring rates....
WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2?
Old Nov 18, 2005 | 12:22 AM
AMECustom's Avatar
Default WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2?
Like the title says. I couldnt find anything when i searched...please help me out..?
Old Nov 18, 2005 | 01:41 AM
AMECustom's Avatar
Default Re: WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2? (AMECustom)
does anybody know??? please
Old Nov 18, 2005 | 02:08 AM
slammed_93_hatch's Avatar
if you switch over the rear LCA's then yes.
EH2 is a 92-95 civic right?
Old Nov 18, 2005 | 08:41 AM
nonsense's Avatar
Default Re: WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">if you switch over the rear LCA's then yes.
EH2 is a 92-95 civic right?</TD></TR></TABLE>
I think he's asking if the GC's that are made for Konis on an ITR will fit Konis on an EH2, not whether the shocks will fit. If that's the case then, yes they should fit fine. AFAIK all honda Konis are the same diameter. You can PM CRX Lee for a definitive answer though.
Old Nov 18, 2005 | 10:24 AM
AMECustom's Avatar
Default Re: WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2? (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
I think he's asking if the GC's that are made for Konis on an ITR will fit Konis on an EH2, not whether the shocks will fit. If that's the case then, yes they should fit fine. AFAIK all honda Konis are the same diameter. You can PM CRX Lee for a definitive answer though. </TD></TR></TABLE>
Yes that was my question, thats what i was thinking. Thanks again, i'll pm him right now
Old Nov 18, 2005 | 06:47 PM
AMECustom's Avatar
bump
Old Nov 18, 2005 | 07:36 PM
yes they are the same OD, GC uses the same sleeves for most honda's for koni's
bigkshep
Suspension & Brakes
Jul 31, 2005 02:16 PM
quisp
21
May 12, 2005 06:51 AM
ITR0962
Apr 11, 2004 12:10 PM
