need help with ecu
Old Nov 17, 2005 | 07:38 PM
TBoDelSol's Avatar
Default need help with ecu
i need some help with my ECU as you may of read b4 my car died and i charged the battery and my car would just turn over but not start. I found out that im not getting power to my ecu/ not sending power to kick the main relay.
I have Checked:
Battery
Starter
Ditributor
Ignitoin
Replaced the ECU with 2 different ones
Replaced teh Main relay with 2 different ones
Check fuel pump
Replaced Fuse board
Modified by TBoDelSol at 4:56 PM 11/18/2005
Old Nov 18, 2005 | 11:52 AM
TBoDelSol's Avatar
Default Re: need help with ecu (TBoDelSol)
BUMP ANYONE PLEASE?
Old Nov 18, 2005 | 11:55 AM
boostedcivicsir's Avatar
Mr. Badwrench
check the grounds on the thermostat housing.
Old Nov 18, 2005 | 12:21 PM
IHateJDM's Avatar
all your fuses good?
Old Nov 18, 2005 | 03:56 PM
TBoDelSol's Avatar
Default Re: need help with ecu (IHateJDM)
yes there good
Old Nov 18, 2005 | 04:07 PM
coquitlamEG's Avatar
take the cover off your ecu and look for any parts that look burnt. Usually when ecu's go bad it's because a resistor fried up. It dosen't happen too often, though.
Old Nov 18, 2005 | 10:58 PM
TBoDelSol's Avatar
i have put in 2 good ECUs so that can be the prob
Old Nov 18, 2005 | 11:08 PM
redhatchDX's Avatar
did you hook up the terminals up wrong? my friend did that on his and he fried everything in the car well we replaced all fuses relays and ground and power wires but after that the radio would come on with the light switch and the lightsd came on with the ignition turned on CHECK EVERY THING!
Old Nov 18, 2005 | 11:32 PM
Default Re: need help with ecu (redhatchDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhatchDX &raquo;</TD></TR><TR><TD CLASS="quote">did you hook up the terminals up wrong? my friend did that on his and he fried everything in the car well we replaced all fuses relays and ground and power wires but after that the radio would come on with the light switch and the lightsd came on with the ignition turned on CHECK EVERY THING!</TD></TR></TABLE>
He's right. If you accidentaly hooked up the battery charger wrong you would completely fry your electrical system. Ground wires would melt, your ecu could fry...
Old Nov 20, 2005 | 01:47 PM
typeoneeg6's Avatar
Default Re: need help with ecu (coquitlamEG)
check the fuse in the fuse box for ecu and check the one that says back up.
hate!
Apr 21, 2013 08:04 AM
95B16-T
Oct 14, 2010 12:10 PM
DCRB
Sep 26, 2010 06:22 PM
2 0 3
Jul 30, 2006 05:36 PM
md88hfcrx
Dec 12, 2005 11:58 AM
