acura emblem
but i dont have a welder. I know you'll probly tell me to go rent one but how much do you think a body shop would ask for this job? I was thinking of getting a paint job anyways. I could get it done at the same time and i might save some cash.
I took off all my emblems and only replaced the A with a red H. In the rear where it said ACURA there are two small holes that you barely notice. I will have them filled when I have the car painted way down the road when I can afford it.
no no no never use body filler (bondo) to fill a hole. body filler is only used to straigten panels. trust me i go to school for autobody. your only solution would be to weld the holes. a halfway expierienced welder wouldnt have a problem doing this. after its welded grind it down and put some body filler or polyester on top....if you really want to do it but dont want to weld buy some fiberglass filler and do it. its still the wrong way but 100 times better than body filler. pm me for step by step info
macco would do them for like 75 bucks i think my friend got his DA (92 teg) repainted and shaved all emblems and it came out amazing 1500 bucks later but they do dents and holes i believe are 50 a pop
like i said, put duct tape on the other side, then put masking tape on top.
get a pencil, and poke some holes out. use a round file and file the tape out where the sides are and clean up the holes.
then, with jb Weld, slap it over the holes and wait a day.
then sand it out clean.
and ur done. u can leave the tape on and use touch up paint. after that, remove the tape.
DONE.
DONE.
