Using only 1 Hasport motor mount? Thoughts/advice?
well i drive a 96 civic with B-series swap, and oem rubber driver side mount ripped. the rest are fine. this is because im not running an AC bracket and tranny bracket mount. no flames plz.
anyway, i was wondering if it is ok if i JUST buy the hasport driverside mount for $165...
or should i buy all 3 (rear, passenger and driverside) for $415.
im a poor college student so money IS an issue. and i WILL be putting on my tranny and AC bracket on at the same time i put the driver side mount on. i would just like to know your experiences, thoughts, and advice... thanks.
Thats what I'm running right now. I ripped two stock mounts in 1 day and I was running the a/c bracket and tranny mount. I guess the stock mounts didn't like my 6puck.
So yes, I think you will be fine with just the HASport driverside upper mount.
.So yes, I think you will be fine with just the HASport driverside upper mount.
