Loud Rubbing Noise
I took my car out for a drive today and as I approach 20+ mph the front passenger side near had a loud rubbing noise. I then pulled over to see if the tire were rubbing but i have about a 1/2 inch wheel gap. As i went faster the noise would keep going and be periodic. Anyone know what it could be? I'm thiniking its the wheel bearing.
LOL how would you know that my hatch has splash guards? My splash guards are new anyways straight from Honda with all the materials needed. And i know its not that.
By periodic do you mean it makes the noise roughly once every tire rotation and rises in pitch the faster you go? If so, it's probably not a wheel bearing. Wheel bearings sound like a grinding all the time and it doesn't change in pitch or seem periodic at all.
And if it only happens above 20mph, then that's more evidence against the defendent
Check for debris under and around your car, wheels and brakes included, and make sure there aren't pebbles or anything jammed in your brake dust shields.
.Check for debris under and around your car, wheels and brakes included, and make sure there aren't pebbles or anything jammed in your brake dust shields.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh »</TD></TR><TR><TD CLASS="quote">So i took it out to drive it again and its a really loud grinding noise and gets worse when i turn..
Either a wheel bearing or an axle. Does it thump or clunk when you turn or hit bumps?
</TD></TR></TABLE>Either a wheel bearing or an axle. Does it thump or clunk when you turn or hit bumps?
took it out to meineke to get my muffler welded and asked them to check my wheel bearing. The guy said he couldnt see anything wrong with it but i dont even think he checked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh »</TD></TR><TR><TD CLASS="quote">took it out to meineke to get my muffler welded and asked them to check my wheel bearing. The guy said he couldnt see anything wrong with it but i dont even think he checked</TD></TR></TABLE>
not too sure and correct me if im wrong but how could he SEE anything wrong with it without taking the assembly apart? i vote for he didnt check it
from drive shaft shop
