which wideband?
Old Nov 17, 2005 | 02:53 PM
crxkid24's Avatar
Default which wideband?
i'm having trouble deciding which wideband i should purchase. i'm stuck between the innovate LM-1 or the PLX M-250 or 300. let me know what you guys think. heres the link to them.
http://www.innovatemotorsports...age=1
http://www.streetrays.com/cata.../8933
http://www.streetrays.com/cata.../2970
Old Nov 17, 2005 | 06:33 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: which wideband? (crxkid24)
i think i am going to buy the plx m-250 cause the price is right and i already have a datalogging setup. the cool thing with innovate though is that it would allow you to do other peoples cars if you didnt install the cable into yours. i have not heard bad things about either though.
Old Nov 17, 2005 | 11:10 PM
crxkid24's Avatar
anyone else?
Old Nov 17, 2005 | 11:22 PM
2k.civic.si's Avatar
Default Re: (crxkid24)
innovate wideband...why? because it is the most accurate out there....its uses patented technology and is as accurate as lab grade equipment...ive personally seen plx widebands be off as much as a full point...i cant speak about any other brand because thats all i have seen...i personally own a innovate lm-1 and can tell you its all its cracked up to be
ps-the innovate lm-1 is the only wideband i have seen that can datalog without a pc...
Old Nov 18, 2005 | 12:01 AM
ppfalcon's Avatar
Default Re: (2k.civic.si)
plx is not the most accurate anymore..DYNOJET WIDEBAND COMMANDER!!!
http://www.widebandcommander.com/
-don't need a laptop
-datalog runs so you can look at it later(without laptop)
-can run off 9v battery
-uses a higher quality Bosch sensor which lasts longer
-better customer support
Old Nov 18, 2005 | 05:26 AM
mmuller's Avatar
Mad Scientist
Default Re: (ppfalcon)
zeitronix
you do need a laptop, but best features for the money.
Old Nov 18, 2005 | 05:48 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">innovate wideband...why? because it is the most accurate out there....its uses patented technology and is as accurate as lab grade equipment...ive personally seen plx widebands be off as much as a full point...i cant speak about any other brand because thats all i have seen...i personally own a innovate lm-1 and can tell you its all its cracked up to be
ps-the innovate lm-1 is the only wideband i have seen that can datalog without a pc...</TD></TR></TABLE>
how did you see it off a whole point? did you have a innovate and plx right next to each other and they were giving different readings? or was the plx sensor mounted farther downstream? do you have any evidence of this? im not saying you are wrong, its just i like to have evidence that what you say is the case.
Old Nov 18, 2005 | 06:10 AM
91civicDXdude's Avatar
i have an innovate LM1. its bad ***.
Old Nov 18, 2005 | 02:16 PM
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">
how did you see it off a whole point? did you have a innovate and plx right next to each other and they were giving different readings? or was the plx sensor mounted farther downstream? do you have any evidence of this? im not saying you are wrong, its just i like to have evidence that what you say is the case.</TD></TR></TABLE>
customer had a plx-300 installed in car...it was reading different from the dyno wideband so we hooked up my lm-1 to confirm....the dyno wideband and lm-1 read the same the plx was off by about .8
if you search ht im not the only person who has found this....
Modified by 2k.civic.si at 11:26 PM 11/18/2005
Old Nov 18, 2005 | 08:32 PM
crxkid24's Avatar
thanks everyone. i purchased the lm-1 today.
Old Nov 21, 2005 | 08:23 PM
crxkid24's Avatar
tuned my car saturday with it. love it!
Old Nov 23, 2005 | 12:07 PM
sanimalp's Avatar
$cat /dev/urandom
[QUOTE=2k.civic.si]
[\QUOTE]
i believe you, i was just trying to see if something wasnt set up right... this is the first time ive heard this but it makes sense that you get what you pay for.
kornkid21792
May 10, 2009 05:11 PM
Nicks95GSR
Dec 3, 2008 09:23 AM
import_kid
30
Nov 16, 2006 07:15 PM
PECO
Honda Motorcycles
Dec 1, 2005 12:34 AM
boostincoupe
Jun 3, 2003 12:05 PM
