FS or Trade Built for turbo GSR longblock with Skunk2 intake manifold
It is a B18C1 out of a 98 Acura Integra GSR. When I bought the engine I was told it has the following installed (I bought it from a friend and I was there for most of the installs so i had no reason to doubt) Mahle 9.0:1 pistons, Eagle H rods, oil pan tapped for oil return line, New bearings, new headgasket, Head has newer oem honda valvetrain(head was taken to a machine shop to make sure everything was straight and it was), Stock GSR cams (guys on HT have hit over 500 WHP with them so he did not replace them), new oem water and oil pump, new timing belt, oem cam gears, anyway it is a complete long block with a Skunk2 intake manifold. The entire setup had less than 6K miles on it when he decided to go with the H22 setup. I removed the Valve cover to get it powdercoated but I never actually got it done. I did strip it down to bare metal so the valve cover is just plain sanded down silver. Oh yeah the valve cover is cut on the end because i planned on getting adjustable cam gears but never did.
Will trade for????? what do you have????
phase@bellsouth.net
phase@bellsouth.net
Yeah I thought you weren't since you didn't get back to me. Email me the pics again please.
phase@bellsouth.net
phase@bellsouth.net
pics? more info on this set-up would help you out. I.E Who did you buy this from? Reputable seller here on HT? Pics? Do you have allm reciepts to prove the parts internally? Thanks
I can get copies of all the reciepts if you need. The guy who i got this from is a local guy not sure if he is on here or not. I have owned my own business for the last few years and he bought all these parts from me and I helped him pull this engine out when he did the H22 swap. That was the only reason he removed this one. Whats your email and I can get you pics. Also I have no use for this engine now so make a reasonable offer and I will get it shipped out ASAP.
GTibunny16v
Feb 1, 2009 05:20 AM
tradesalot
Dec 11, 2005 01:19 PM
