Defi D-Gauge owners, i need your help **please look**
Old Nov 17, 2005 | 01:31 PM
itralex's Avatar
Default Defi D-Gauge owners, i need your help **please look**
I just recently purchased 2 Defi D-gauges from Evasive Motorsports ( ) along with 2 52mm meter cups and mounting hardware
When looking at the back of the gauge there are 2 long studs that stick out which i have no clue what they're there for, but they are there. However there is no holes on the meter cups to allow these studs to remain while the gauge is mounted in the cup.
So i am wondering how did you mount the gauges with the studs (what did you do with them, cut them off or drilled holes in the cup?) and if not, did you cut them off, and if you did cut them off, were there any rattling because of the head that is still stuck inside the gauge?
TIA
Old Nov 17, 2005 | 01:37 PM
Opie's Avatar
I have Defi D gauges in my R. However, I used the Autometer guage bezel to mount mine. The 2 studs weren't a problem. Which munting cup are you talking about? My gauges didn't come with them, were they a seperate purchase?
Old Nov 17, 2005 | 01:42 PM
itralex's Avatar
Default Re: (Opie)
I'm using the defi mounting cup and mounting hardware (Part# PDF01903G) I had to buy these separately as the D's don't come with any mounting hardware
so did the 2 long studs fit fine into the autometer cup?
Old Nov 17, 2005 | 03:01 PM
white rocket's Avatar
Default Re: (itralex)
Well, you saw mine Alex. They fit fine in the Autometer cluster bezel. My set-up is the same as Opie's. I'm not sure about the Defi cups though.
Where are you putting the gauges? Dash? Vents?
Old Nov 17, 2005 | 03:26 PM
itralex's Avatar
Default Re: (white rocket)
Yeah chris, yours look pretty good
I'm gonna mount my on the dash
here are some pictures
Old Nov 17, 2005 | 03:50 PM
Those cups look great. Mounting the gauges on the dash will look awesome.
Judging from your pics, those bolts look useless. I'd say dremel them off so the gauges fit in the cup. I don't remember those bolts being on the back of mine though.
Old Nov 17, 2005 | 04:24 PM
Phoenix_ITR's Avatar
it looks like the studs are just threaded into the back of the gauge. have you tried backing off that locknut? you might be able to double-nut the end of the stud and simply thread it out.
Old Nov 17, 2005 | 04:28 PM
Dave-ROR's Avatar
Default Re: (Phoenix_ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix_ITR &raquo;</TD></TR><TR><TD CLASS="quote">it looks like the studs are just threaded into the back of the gauge. have you tried backing off that locknut? you might be able to double-nut the end of the stud and simply thread it out.</TD></TR></TABLE>
I agree, from the pics it looks like you may be able to double nut them to remove them.
Old Nov 17, 2005 | 04:42 PM
itralex's Avatar
Default Re: (Dave-ROR)
I've actually tried to disassemble the gauge to remove the stud. However, i could not detach the gauge from the plastic screen up front without alotta force.
so yeah, i've also took off the nut and realized that its a screw with a nut on the outside holding it in place so it doesn;t wiggle
Old Nov 17, 2005 | 06:38 PM
Jspectyper's Avatar
cut them off...done that with some old autometers of mine
Old Nov 17, 2005 | 08:11 PM
yellow blur's Avatar
Default Re: (Jspectyper)
Alex,
Thanks for the purchase. I didn't even bother to think about that as a problem. I agree with most of the guys here, you can just cut off the portion of the stud that is sticking out. I don't know if I would really try and open up the gauge, not a good idea if something were to go wrong. Everything looks good though, post pictures when you're done mounting them!
Ed
Old Nov 18, 2005 | 01:32 AM
itralex's Avatar
Default Re: (yellow blur)
i guess the consensus is to hack those lil buggers off
i'm gonna try to get my hands on dremel and see how install goes
thanks everybody, and big thanks to Evasive (yellow blur) for having them sent up here to canada soo quick
Old Nov 18, 2005 | 10:37 AM
citrus3000psi's Avatar
I had some autometer guages with those same rods sticking.
A big pair or wire cutters handled the job quite well.
Old Nov 28, 2005 | 02:44 AM
itralex's Avatar
Default Re: (citrus3000psi)
ok, i ended up hacking them off, but ran into fitiment issues. The guage doesn't sit all the way into the cup as the back of cup has a indentation. But i'm not bothered by it. i probably super glue it or something.
I've already hooked up the sensor wiring, just gotta do the electrical wiring. I've read 92typeR's thread and will looking to attempt his wiring schematic
mouab18c1
Feb 5, 2010 11:22 AM
5STAR3
Feb 28, 2004 12:20 PM
HONDA-2NR
Feb 24, 2004 04:31 PM
mini-cRx
Jun 5, 2003 06:54 PM
yellow blur
Sep 13, 2001 03:06 PM
