Spoon bushings
My 97 has spoon poly bushings on it. They squeak so loud after every little bump on the road. Does anybody else have this problem with there bushings? and what do you do. Does greasing them up work?
Modified by Typer#23 at 3:07 PM 11/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typer#23 »</TD></TR><TR><TD CLASS="quote">My 97 has spoon bushings on it. They squeak so loud after every little bump on the road. Does anybody else have this problem with there bushings? and what do you do. Does greasing them up work? </TD></TR></TABLE>
I assume they are poly bushings?
If so, using the proper lube/grease will remove the squeak's for a bit, then it'll be time to repeat the process.
-Dave, who just turns the stereo up.
