brake light stuck on?
Old Nov 17, 2005 | 12:45 PM
intech's Avatar
Default brake light stuck on?
can any one tell me why the brake light would be stuck on? the e-brake is not stuck and i have no other problems. just the parking brake light in the gage pod is stuck on. sometimes it will turn off on its own,sometimes flicking on and off and do you know how to fix the problem? thanks
Old Nov 17, 2005 | 02:44 PM
Sam92Teg's Avatar
Default Re: brake light stuck on? (intech)
Check your brake fluid in the resevoir, and the connections to the sensor at the resevoir. If it is low on fluid, the light comes on. Could be something else, but this is the first thing you should check.
el_huevoEK2099
Suspension & Brakes
Apr 4, 2009 05:55 AM
BukThout
Apr 10, 2007 07:44 PM
sullycrx
Nov 16, 2005 09:48 PM
TRN
May 24, 2004 12:03 PM
hybridbmw
Feb 19, 2002 10:38 AM
