can i attain 200 whp with what i have listed?? opinions??
Old Mar 11, 2002 | 06:36 PM
acurism's Avatar
New User
Default can i attain 200 whp with what i have listed?? opinions??
well, my goal is to get tp 200 whp.
I currently have a JDM b18c w/ aem cai, skunk2 manifold, JDM ITR headers, Clutchmasters stage III flywheel and clutch, Tanabe Hyper Medallion exhaust.
im curious what to do with cams because i want something that can be daily driven and be my weekend warrior. Ive seen a lot of guys get good results with the Jun III's. How practical are they for a car that is daily driven??? pending on if they will be ok for daily driving I was planning to go with those along with a Hondata program so I can get someone to modify my pr3 ecu on the dyno to get the maximum out of those cams. Other than that I was planning to get a FPR.
With JUN III's cams and camgears,springs,retainers, Hondata tuning, and a FPR along with lots of tuning on a dyno is it a feat that can be attained with those mods????
Old Mar 11, 2002 | 06:39 PM
comptechgsr's Avatar
Default Re: can i attain 200 whp with what i have listed?? opinions?? (acurism)
jdm b18c?
1 or 5
Old Mar 11, 2002 | 06:41 PM
acurism's Avatar
New User
Default Re: can i attain 200 whp with what i have listed?? opinions?? (comptechgsr)
just like it says. b18c
the jdm gsr version is b18c and the us version is b18c1
Old Mar 11, 2002 | 06:50 PM
BADxPNOI's Avatar
well first off if you really want to get 200whp youre going to have to spend money on dyno tuning youre car from a reputable shop. with the items youve listed youre not going to reach the goal that youve set yourself, no matter what the magazines say. 200hp out of our 1.8L engines without F/I is going to take a lot more than that...it includes but is not limited to big t/b, port matched intake manifold, cams designed for highly tuned n/a applications like jun-3 or toda spec b, valves and valve springs, high compression pistons (11:1 to 11.5:1), head work, and some really really good exhaust...JDM exhausts have the 2.5in collector which is a whole *** load better than any header made in the US (of which have to be CARB legal meaning they can only get as big as 2.25in) a Carsound catalytic converter and a cat-back thats 2.5in allt he way to the muffler. after that you wanna spend a whole lotta time tuning... and if you REALLY wanna spend money (and time) you might want to consider increasing the displacement from 1.8L to 2.0L , all in all you would be looking at.....$3000 or $4000 depending on what products you buy and how much labor youre charged.
Old Mar 11, 2002 | 07:08 PM
Pinhead's Avatar
New User
might want to consider raising ur compression for jun3's
Old Mar 11, 2002 | 07:09 PM
acurism's Avatar
New User
check out this link~~~~
http://www.importreview.com/dyno/1.8/GSRJUN.html
Old Mar 11, 2002 | 07:10 PM
Spyderwebab's Avatar
Your going to have to get higher compression pistons in order to hit 200whp...I'm only getting 175 w/ the toda B's...
Old Mar 11, 2002 | 07:13 PM
acurism's Avatar
New User
Default Re: can i attain 200 whp with what i have listed?? opinions?? (Spyderwebab)
well i can boost my compression a little by getting a spoon one layer head gasket. what kind of high compression pistons do you recommend?? type r, arias?? what else. by the way thanks for the replies.
Old Mar 11, 2002 | 07:24 PM
Erik_Pb_Foot's Avatar
New User
Default Re: can i attain 200 whp with what i have listed?? opinions?? (BADxPNOI)
I really don't agree with most of that. With the right valve train and ecu, along with good tuning and your current mods, i believe you would hit the 200 whp mark. i TOTALLY agree of the 2.5" collector and cat-back though... very true. 11.5:1 CR would be ideal, 12:1 if your local gas stations and wallet permit. Port and polish, I'd say stage 2 or 3, with a 3 to 5 angel valve job and oversized valves would help a lot. i'd also look @ the toda spec c's... very comperable to JUN IIIs from what I've seen.
Old Mar 11, 2002 | 07:25 PM
New User
Default Re: can i attain 200 whp with what i have listed?? opinions?? (Pb_Foot)
JE 12:1 would be great
Old Mar 12, 2002 | 08:47 PM
BADxPNOI's Avatar
in youre signature, you say you have a tanabe exhaust. im pretty sure that tanabe exhaust has a problem with the piping, the diameter tapers down from the cat to the muffler, i bet you if you changed to like Hy-tech or SMSP youd get near 200
Old Mar 12, 2002 | 08:51 PM
BADxPNOI's Avatar
anything higher than a 11.5:1 CR i would seriously be thinking of re-sleeving your cylinders....pressures will get up REALLY high with that kind of ratio and if you push it, the walls will crack. also think about new connecting rods, rings, and reliable people installing all that crap
revikan
22
Jul 28, 2013 11:56 AM
l-99-em1
Jul 26, 2010 08:24 PM
jdmmanek
May 11, 2007 07:46 PM
littlegreenb18
16
Jul 29, 2005 05:39 AM
yeegsr
Nov 26, 2004 01:46 PM
