need help with ZC motor
I just bought a DOHC ZC motor for $50 and there are a few parts missing here and there, i need to know which parts are interchangable with different series motors.
what i need:
all 4 fuel injectors
distributor (complete)
fuel rail
throttle body
timing belt
i know it is practically the same motor that is in an 88-89 integra, so those parts are an option. i was wondering if i could use parts from an 88-91 civic/crx si or a 90-91 integra with no modifications. also, what timing belts will work for this motor? im told the only thing that matters with the timing belt is the "length" of it..but i dont know the measurement and i need a part from honda, i dont think the honda dealership carries acura parts and i have a timing belt for a sohc d series that i was going to trade in (hasnt been opened)
what i need:
fuel rail
throttle body
timing belt
the dissy, fuel injectors, and fuel rail is the same as a d16a6, i forget what the timing belt is, and i thiknk the TB is the same as the a6 also. I would check on the TB htough. you can go to thezcr.com or d-series.org.
TB from A6 works for sure. Not sure about fuel rail, but i think it doesn't work. Dizzy from A6 absolutely does not work. Timing belt is longer. I don't know D16A1 but i think most parts will work with DOHC ZC.
check thezcr.com for answers.
phoQ
Mar 8, 2005 10:37 AM
Nacho169
Jun 2, 2004 07:11 AM
DelSlowTurbo
10
Feb 22, 2004 10:37 AM
