Fuel injectors not getting signal...help?
Old Nov 17, 2005 | 10:52 AM
shyboi4u's Avatar
Default Fuel injectors not getting signal...help?
i'm having problems with my fuel injectors. we tested the harness to see if its getting power on initial start, it has power. we hook a noid light to see if its getting signal, its not blinking like it should be. we changed ecu, dizzy, main relay and we still not getting the pulse. i messed with the passenget side harness in the engine bay. unplugged then plugged back in. we tried the noid light and we was getting the pulsing. plugged the injector and the motor started. we let it run with now problem. we shut it off. in bout 5 minutes, we tried to start it. same problem again. What could be the problem?
Old Nov 17, 2005 | 01:05 PM
shyboi4u's Avatar
Default Re: Fuel injectors not getting signal...help? (shyboi4u)
is this honda TECH?
93accordmike
Jan 19, 2012 12:22 PM
kseriesdreams
Apr 20, 2011 09:24 AM
DC2R96
Mar 3, 2011 06:09 PM
gwilguy
Aug 22, 2010 04:35 PM
CLE
Jul 13, 2006 02:25 PM
