Spoon n1/b pipe help!! tech question...
Old Mar 11, 2002 | 06:22 PM
SpoonSiR2's Avatar
Default Spoon n1/b pipe help!! tech question...
ok guys, here is the deal..i have a jdm 4-1 header, spoon n1 axel back, adrian teo high flow cat, and b pipe.. but my problem is..the header is 2.5', cat is 2.5', spoon n1 axelback is 2.5'...but the b pipe is 2.25..will it work?
Old Mar 11, 2002 | 06:24 PM
DragII's Avatar
25 Year Member
Default Re: Spoon n1/b pipe help!! tech question... (SpoonSiR2)
will it work? yes.
should you upgrade? yes.
Old Mar 11, 2002 | 06:26 PM
SpoonSiR2's Avatar
Default Re: Spoon n1/b pipe help!! tech question... (EvilDragII)
but for now itll work right? i just cant afford a b pipe righ tthis moment..
Old Mar 11, 2002 | 06:27 PM
DragII's Avatar
25 Year Member
yeah, sure it will work...you'll just get better flow when you eliminate that lil bottle neck..
for now...your good to go
Old Mar 11, 2002 | 06:41 PM
SpoonSiR2's Avatar
will it bolt right up though? thanks bro...
Old Mar 11, 2002 | 07:02 PM
bhcvc's Avatar
I thought the spoon n1 axle-back was 60.5mm, which is 2.38", not 2.5". At least that's what it says in my spoon catalog. did they change it recently?
oh, and as for will it bolt up, as long as the bolt holes in the flanges line up, everything will bolt-up fine.
Old Mar 11, 2002 | 07:03 PM
fowler!'s Avatar
I thought that the Spoon axle back was only 2.25"
Old Mar 11, 2002 | 07:08 PM
Brian*'s Avatar
you'll be fine billy. for a while i had my 2.5" cat going into a stock Si b-pipe. was there a difference after i changed it to a 2.5" bpipe? lord yes
Brian
Old Mar 11, 2002 | 11:51 PM
From: LA, Hawthorne, Alhambra, Monteghetto, CA, USA
are you planning to get the spoon b-pipe? if so, let me know, i can get them for you....
Old Mar 12, 2002 | 06:29 AM
SpoonSiR2's Avatar
Default Re: Spoon n1/b pipe help!! tech question... (SPOON EG)
thank you guy!! Brian, you da' man!!
Old Mar 12, 2002 | 07:29 AM
Jackson's Avatar
what b-pipe are you going to use? that is pretty close to what i am using.
mtny
Aug 21, 2007 02:15 PM
JDMDC4life
Nov 22, 2006 05:54 AM
.water
Nov 17, 2004 02:48 AM
rodimus
20
Jan 7, 2004 06:49 AM
JDM_Type-R
Jan 23, 2002 12:02 AM
