FS (WI) LS Hydro tranny, OBDII Disti, OBDII Wire harness, Etc...CHEAP!
Old Nov 17, 2005 | 09:10 AM
wreckedmyteg's Avatar
Default FS (WI) LS Hydro tranny, OBDII Disti, OBDII Wire harness, Etc...CHEAP!
Following items for sale, picked up or shipped...
98 B20B Distributor - $100.00
98 B20B Wire harness, uncut, perfect condition - $90.00
98 B20B Fuel injectors (flow more then LS?) - 60.00
98 B20B Crank pulley (good for Jackson SC?) - $55.00
98 B20B Throttle body with sensors - $50.00
98 B20B AC Bracket with tensioner - $50.00
98 B20B Fuel rail and pressure regulator (looks billet) - $40.00
98 B20B Intake manifold with all sensors - $20.00
98 CRV Drivers side engine mount - $15.00
94 B18B Transmission, 120k-ish miles, does not grind or make weird noises - $400.00
94 B18B Complete short block, bad rod bearing (pulled because of knock) - $175.00
94 B18B Cylinder head - $100.00
94 B18B Cams (good for regrind core) - $75.00
94 B18B Water pump - $20.00
94 B18B Thermostat and water neck - $20.00
90 Civic SI hatch - clear tails - $30.00
ZC (88-89 Integra) MSD distributor cap (brand new, 5 post) - $35.00
90 Civic SI hatch DINAN ECU (big gains, complete DINAN ECU, not re-chip) - $100.00
90 Civic SI Clutch kit, brand new in box - $125.00
90 Civic SI Front struts, brand new in box, Monroe Sensitrac - $50.00
90 Civic SI Front axles, brand new in box - $60.00
B18B is bare long block at the moment, sell complete for $400.00
Chambered 3/4" MDF box, for 3 10"'s, .75 cu ft per chamber, carpeted and v-blocked - $50.00
Front seats from 93+ Civic, black vinyl - Free (pick up only)
88-91 Civic Q-Forms - $35.00
Jacobs Omni ignition, with secondary trigger - $75.00
All prices are negotiable, feel free to low ball.
Also have a 95 GSR coupe, stock, Milano red, new clutch, with *mint*, and I do mean *mint* blades for sale. 322k, mostly highway (commute from Fox Valley to Milwaukee), with receipts for EVERY oil change and repair. Strong runner, does not knock or smoke. Leather interior, no rips, and factory alarm. Normal wheel well rust. Make offer.
Old Nov 17, 2005 | 11:39 AM
JUN1OR's Avatar
Default Re: FS (WI) LS Hydro tranny, OBDII Disti, OBDII Wire harness, Etc...CHEAP! (wreckedmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">Following items for sale, picked up or shipped...
From your DC4? Still have that huh. Should have posted this a while ago.
good prices.
Free seats?
EDIT - Might want to post here:
http://hondamarketplace.com/zerothread?id=1419817
Old Nov 17, 2005 | 11:51 AM
Default Re: FS (JUN1OR)
Yup...Pulled it at least 2 years ago.
dmotoguy
Nov 9, 2007 10:29 AM
wreckedmyteg
Nov 22, 2006 12:04 PM
Gr0c3ryG3tt3r
Nov 7, 2005 06:22 PM
JDM RHD eg6
Aug 1, 2005 10:01 PM
pattonxbody
Sep 5, 2004 02:14 PM
