Audio: RSX deck to INtegra
As long as it's not the Bose system and just the standard single din one piece HU you should be able to make it work, you will probably need 2 adpt. harness, one for the HU, [unless the oem one was cut out of the car it came out of] and the one that plugs into the tegs oem radio harness, [unless it has already been cut out].
The metra 71-1721 will plug into the RSX HU and the 70-1720 will plug into your teg
You may also need to make your own mounting brackets as I am not sure thy use the same mounting system.
94
94
gokooljapan
Jun 7, 2005 07:52 AM
