es motor mount inserts
this weakend im putting a new tranny in my ej1 and i have es motor mount inserts laying around and was wanting to know if they are worth putting in??? i have heard stories of te dash and whole car vibrating horribly bad afterwars is this true?? is it possible to just slap the tranny and rear inserts in or would that cause the other motor mount to give out quickly??? i have heard if u put one in u better put the rest in because of problems with the other mounts is this true???
I dont think the ES motor mount bushings are hard enough to shake the whole dash unlike Hasport or place racing mounts. The rubber is just slightly harder and firmer then stock. It should feel alot better. You can just put them in but there supposed to be pressed in at a shop.
i didnt ever hear that they are suppose to be pressed in? so there not gonna make me hate my card cuz of vibrations being so bad???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc »</TD></TR><TR><TD CLASS="quote">i didnt ever hear that they are suppose to be pressed in? so there not gonna make me hate my card cuz of vibrations being so bad???</TD></TR></TABLE>
No they shouldnt vibrate to much at all. Should just feel slightly/mildly firmer then stock. They recommend being pressed in I beleive although you dont have to.
Guest
Posts: n/a
there are 2 types... some mount inserts are just to be inserted and not be hydraulic pressed in. fits like a puzzle... the other ones are mount insert replacements. these are the actual ones needed to be pressed in. pretty much, only the driver (upper) mount needs a press. i have ALL 5 inserts... and i only neeeded to machine in the upper driver one.
civicsi18
Oct 27, 2008 12:05 PM
b16a2EBP
Mar 20, 2006 11:55 PM
onyx00
Sep 24, 2004 01:00 PM
