b16a o2 sensor...help!!
Old Mar 11, 2002 | 05:43 PM
from_zer0's Avatar
Default b16a o2 sensor...help!!
OK, here's the situation:
Check engine light kicks on @ highway cruise...Turn the car off and start it again, no light. The ECU is throwing code 1. Oxygen content. Reset the ECU, drove around for a little bit, ran it up to high RPMs a few times, drove home, all's well.
So what does this mean?? Does the sensor need checking/replacing? Should I wait to see if it pops up again? What else might cause this code?
If it does end up needing to be replaced, can a muffler shop do so while replacing my exhaust? What's an acceptable price for parts/labor?
Not too fond of the check engine light, so any replies would be great. If it needs replacing, I'd like to know ASAP, so that I can have it done along with some other work.
Thanks alot!!
Old Mar 13, 2002 | 02:56 PM
iwhichisme's Avatar
Default Re: b16a o2 sensor...help!! (from_zer0)
how many o2 sensors are you running?
jjenkins
Mar 6, 2010 08:37 PM
IP RACING
Jan 29, 2008 06:53 PM
Mad Money
Sep 27, 2006 08:22 AM
alotawatts
Nov 28, 2004 01:21 PM
