rough idle
Old Nov 16, 2005 | 09:39 PM
civiccoupe94's Avatar
Default rough idle
my 94 dx motor is running rough on idle, and i dont know what it is. i changed the oil, intake filter, spark plugs, etc. would it be caused by a bad pcv valve or something? its been getting more and more rougher ever since i had it a year ago. has about 175k and been abused pretty badly by the previous owner and myself.. im looking forward to get a swap, but not enough money as of right now so i need it running a bit better. thanks
Old Nov 16, 2005 | 09:53 PM
THC07's Avatar
Default Re: rough idle (civiccoupe94)
give little tune, what do you mean rough, is the tech neddle go up and down? or sit still at 700rpm? or is it rough like its missing?
Old Nov 16, 2005 | 10:06 PM
n8byte's Avatar
maybe your spark plug gaps are off or your engine is getting tired if it was drivin rough you could always do a compression test, or is it eating oil? If your rings are getting bad your plugs can get oil fouled quick i did that to my teg Geez you live in seattle?? ill fix it we washitonians gotta represent lol
Old Nov 16, 2005 | 10:10 PM
civic_driver's Avatar
timing, bad pcv, bad o2 sensor, bad spark plug gaps, bad plug wires, bad dizzy/internal parts, clogged fuel filter, clogged injectors, valve lashes out of spec, idle speed, IACV, FITV, vacuum leaks, air in coolant, loose connections, bad grounds, TPS, MAP sensor... all of these and more could be responsible for a bad idle... if you'll be swapping soon it's not worth it.... otherwise you could start troubleshooting parts one by one
Old Nov 17, 2005 | 12:05 AM
i changed the fuel filter, timing belt a few months ago. its rough as in like shakeing, but once i hit the gas to about 2000+ rpm, it gets normal. would it be that the engines getting old? its been beat up pretty bad my my friend that owned it before me, but i got a great deal on the car and was planning to do a swap.
Old Dec 8, 2005 | 06:40 PM
HatchAdams's Avatar
Default Re: (civiccoupe94)
did you have any v-tec controller on it at all?
Old Dec 8, 2005 | 07:04 PM
white92eg9's Avatar
air ideal control valve
Old Dec 9, 2005 | 12:00 PM
SicilianSpeed42's Avatar
Default Re: (HatchAdams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchAdams &raquo;</TD></TR><TR><TD CLASS="quote">did you have any v-tec controller on it at all? </TD></TR></TABLE>
Its a DX, non vtec.
My b7 idles a lil rough too. when im stopped the car vibrates a bit but if i give it a lil gas its fine. I havent gotten around to it yet.
alexahudson78
Jul 31, 2018 01:13 PM
JDM_nUt
Aug 27, 2013 02:29 PM
95_DB7
Aug 31, 2012 09:56 PM
boost4life1
May 15, 2012 08:52 PM
SomeDude56
Oct 9, 2005 10:40 AM
