weird problem when engaging in first gear aHHHH!
Guest
Posts: n/a
aight I dont really know what to put in search, and clutch came up with a millino results
aight heres the problem
3 days ago at a stop, I put it in first and let go of clutch and gas and it kinda bogged but not engine bog, kinda like a drivetrain bog. well anyways it happened yesterday too but today
I put it in first and same thing happen. it felt like something is spinning but slipped. the rpms arent jumping up like in neutral it kinda like the feeling when you stall. it kinda grinds but not CA CA CA CA CA grind like throwing in reverse sometimes, but grind like DU DU DU DU DU.
oh yea and I noticed sometimes the shifter is smooth as hell, and sometimes its notchy to the point that its annoying
new clutch and MCC installed less than 6 months ago
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITB »</TD></TR><TR><TD CLASS="quote">it kinda grinds but not CA CA CA CA CA grind like throwing in reverse sometimes, but grind like DU DU DU DU DU.
haha
haha
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum Playa »</TD></TR><TR><TD CLASS="quote">when was the last time you changed your clutch, if you ever even changed it? I say its the clutch, you may want to look into a new one.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITB »</TD></TR><TR><TD CLASS="quote">new clutch and MCC installed less than 6 months ago</TD></TR></TABLE>
^^oh sorry man, it just sounds odd like ur clutch is slipping are u sure it was installed right. if now i would say crack open your trannys. the easy thing is it's either one of the other u know. sorry man
