jdm itr cluster in gsr Q HELP!!!
just like the title says a i have a 99 gsr and i just bought a jdm itr cluster
everything is working good except for the gas meter
does not work. can any of u guys post a link were i can find the wiring diagram to make it work??? i wold really apreciated
ohhh before i forget, i dont know what year the itr cluster is!!!!
any help would be very apreciated
If there's a third icon between the CEL and Oil Pressure lights, then it's a 96 Spec and you will either need to repin the cluster harness or swap over the gauges into your 99 housing.
i got the ITR cluster as well and had the same problem. there is one part missing on your ITR cluster. this is the gas meter itself!!!! just replace it from old cluster to your type r one. here is a picture for you -->. should be very easy
Chris.B.
Texas -OK -LA (Sales)
Jan 11, 2011 05:44 PM
hans stoner
Dec 26, 2003 12:02 PM
