radiator fan doesnt turn off
Old Nov 16, 2005 | 08:21 PM
calvinnguy3n's Avatar
Default radiator fan doesnt turn off
95 integra ls with 140k miles
the radiator fan doesnt turn off even when the car has been off for several hours ..
any ideas on whats happening?
Old Nov 16, 2005 | 08:29 PM
projectTeG's Avatar
the switch might be bad, also are you sure its not the condenser fan?
Old Nov 16, 2005 | 08:37 PM
thanks for the help, im pretty new to cars so im not really sure which fan it is
Old Nov 22, 2005 | 08:47 AM
SgtRauksauff's Avatar
Default Re: fan stuck on
I've actually got a friend with a '95 LS also, same exact problem. Unfortunately, I haven't had time to look the car over and do any troubleshooting for him.
This switch mentioned, do you mean a temperature switch, usually mounted in the radiator or thermostat housing, or do you mean the relay?
I'm not sure either whether it's the condenser fan or not, I'll have to find out when I look at the car. Does the condenser fan come on only when the A/C is on, or does it get turned on also when the temperature gets above a certain point?
I haven't really worked on any hondas/acuras before, but this is pretty basic stuff, as far as troubleshooting goes, I'm just wondering if there are some well-known common issues with this year/model or something.
thanks much,
--sarge
Old Nov 22, 2005 | 09:48 AM
The Tech-1's Avatar
Default Re: radiator fan doesnt turn off (calvinnguy3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinnguy3n &raquo;</TD></TR><TR><TD CLASS="quote">95 integra ls with 140k miles
any ideas on whats happening?</TD></TR></TABLE>
That happened to me, my relay was fried. Check that.
Old Nov 22, 2005 | 10:31 AM
acuramike's Avatar
fan switch is bad
Old Nov 22, 2005 | 10:35 AM
The Tech-1's Avatar
a common thing on 3rd gen tegs if for the radiator switch to go out. its located behind the distributor, down towards the intake manifold flange.
the fan relay is in the fuse box in the engine bay. It will be the one that is near the battery it is in the far back. there is also a relay hidden in the dash somewhere.
double check your fan sensor switch at the themostat and the themostat itself.
Hope this helps.
Old Nov 22, 2005 | 11:07 AM
M Coop's Avatar
I'm thinkin it's the relay for the AC fan. Had it happen on and old CRX supposedly because water got into it. Best way to check without spending a lot of money is to switch it with another one on the car, I think on the CRX it was up close to the radiator, would think it would be in a similar place on the teg, if you don't know, they're a little 1.5 inch by 1 inch black box with a 3 or 4 wire plug.
jacollins5
Honda Civic (2001 - 2005)
Sep 17, 2016 01:02 AM
Tdawg_1993
Jun 30, 2015 04:33 PM
Lloyd Xmas
Nov 28, 2009 03:42 AM
fast22civic22
May 31, 2007 09:34 AM
