Omnipower Coilovers Thump noise... anyone fix?
Old Nov 16, 2005 | 07:00 PM
syked's Avatar
Default Omnipower Coilovers Thump noise... anyone fix?
Ive got the omnipower full street coilovers on my car and ever since I got them Ive heard loud thuds coming from the rear. Everything is tightened down and i even sent them back to omni to inspect. im still hearing the noise. its annoying as hell and one reason why i might be switching to a different suspension.
However, i was just wondering if anyone has been able to remedy this problem. i know ive read other people having the same problem.
Old Nov 16, 2005 | 07:03 PM
nine78guy's Avatar
Default Re: Omnipower Coilovers Thump noise... anyone fix? (syked)
well, i got only the sleeves, and slammed it on stock shocks, they be alright without making noises at the moment.
Old Nov 16, 2005 | 07:06 PM
Vtec_Dude's Avatar
you think your wheel might be hitting the fender?? I was thinking the same thing you were when i had my suspension setup. I just had someone move the car up and down. If it aint that you should check out the bushings.
Old Nov 16, 2005 | 07:09 PM
syked's Avatar
no rubbing at all. bushings are fine... ?????
Old Nov 17, 2005 | 08:46 AM
syked's Avatar
bump
Old Nov 17, 2005 | 09:34 AM
lonefuzzy79's Avatar
when does this thud happen? Is it on rebound? You might be hearing the piston slamming back into position on rebound and hitting the top of the cylinder. I know of another brand of shocks that does this. If this is the case you might try spring tenders to get the piston to float just below the top of its travel.
Old Nov 17, 2005 | 10:40 AM
syked's Avatar
not sure if it does it on rebound, ill have to pay attention to it tonight when i go out. but it seems like it does it more at slower speeds.
Old Nov 17, 2005 | 10:49 AM
Hi-Boost-EJ1's Avatar
I roll the slip overs, and sometimes i hear a loud thump on rebound from my left rear. I thought that it had to do with weight, but with four people in the car it still does it. i was thinking that it might be the spring un-seating and then slapping back into place, but i have no way to know cuz i cant see back there while im driving.
Old Nov 17, 2005 | 11:04 AM
TsukubaDreams's Avatar
Default Re: Omnipower Coilovers Thump noise... anyone fix? (Hi-Boost-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hi-Boost-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I roll the slip overs, and sometimes i hear a loud thump on rebound from my left rear. I thought that it had to do with weight, but with four people in the car it still does it. i was thinking that it might be the spring un-seating and then slapping back into place, but i have no way to know cuz i cant see back there while im driving. </TD></TR></TABLE>
BINGO happens to me all the time... dont know how to fix it. No big problem, just something to deal with.
Old Nov 17, 2005 | 11:32 AM
Chong's Avatar
ballin
Default Re: Omnipower Coilovers Thump noise... anyone fix? (TsukubaDreams)
I have omni's, never had this problem. Free bump for u
Old Nov 17, 2005 | 11:34 AM
Andres-eh2's Avatar
do those come with pillow ball mounts?
Old Nov 21, 2005 | 06:52 PM
syked's Avatar
anyone?
Old Nov 21, 2005 | 06:53 PM
ZacCarter's Avatar
My omni's do the same damn thing, i just go slow over bumps.
Old Nov 23, 2005 | 11:50 AM
DB1_559's Avatar
that happens to me when i dropped my eg on coils untill i changed my shocks now no noise
Old Nov 23, 2005 | 12:39 PM
A.E Motoring's Avatar
Default Re: Omnipower Coilovers Thump noise... anyone fix? (jdmboi86)
check all you bolts to your control arms and such, and trailing arms, never know might be something lose
Old Nov 23, 2005 | 02:45 PM
NineTwoSi's Avatar
A friend of mine has the same problem and we haven't figured it out yet... Bump for an answer.
Old Nov 23, 2005 | 04:15 PM
deviant1's Avatar
Default Re: Omnipower Coilovers Thump noise... anyone fix? (NineTwoSi)
bump for you. i have the same thud with my omnis.
Old Nov 24, 2005 | 12:28 AM
Andres-eh2's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">do those come with pillow ball mounts?</TD></TR></TABLE>
Old Nov 24, 2005 | 05:18 AM
Jay_Sensing's Avatar
Did you set the preload on the springs properly? I just did a full omni install this weekend for a friend, forgot to set the preload on the drivers front. Had the same noise coming from the coil over as you are describing. It was the spring coming unseated on extension and slamming back into place.
Old Nov 24, 2005 | 08:57 AM
1995Civic's Avatar
Default Re: Omnipower Coilovers Thump noise... anyone fix? (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">check all you bolts to your control arms and such, and trailing arms, never know might be something lose</TD></TR></TABLE>
I had this problem w/ springs. It ended up being the Shock was not bolted down under the hood, and was taking no absorbment. It was just slamming down on the spring. All fixed now though
Old Nov 28, 2005 | 08:05 AM
TahitianEG's Avatar
I installed the omni coilovers and have a thud also. It's only in one, the rear passanger side. My thud seem to happen on compression, but sometime is sounds like it's on the rebound also. Sometimes it sounds like a long screw scaping it's threads on a piece of metal. It also seems to be worst early in the morning when it's cold. 45 - 50 degrees, cold for SoCal . I'm thinking of switching my rear around to see if the sound shifts to the drivers side. That way I'll know if it's the coilover or something else. We'll see.
Old Nov 28, 2005 | 08:09 AM
ROK801's Avatar
probably your problem right here...
Old Nov 28, 2005 | 08:13 AM
MiMiK's Avatar
mine does it with koni yellows and ground controls. it's just the spring unseating then popping back into place.
Old Nov 28, 2005 | 08:32 AM
BiG Chris's Avatar
yea ive done suspension work in the past and its either the spring re-seating itself or the spring compressing on itself those make noises itself
Old Dec 13, 2005 | 02:21 PM
TahitianEG's Avatar
Default Re: (BiG Chris)
What about a coil over where the spring is pre-loaded? With my wheel in the air up on jack stands I can't rotate my springs, yet I have a thud both at compression and rebound. Not only that, but it sometimes sounds like a bolt sliding up and down rubbing against the threads. Now before someone asks if everything is tight, I've double checked everything.
