Wierd tire wear; looks like camber but it's not!
Old Nov 16, 2005 | 02:38 PM
chimchimm5's Avatar
Default Wierd tire wear; looks like camber but it's not!
I've been suffering this problem for awhile now.
Problem: the inner front right tire ONLY is wearing down faster than the rest of the tire and all other tires.
Facts:
- H&R spings, KYB AGX struts, '99 Si 15" rims, everything else is stock
- alignment was checked professional twice, 6 months apart, and both times alignment was within spec (camber, toe, castor)
- car has never been in an accident
- bushings are is reasonable shape and wheel cannot be jiggled by hand when car is raised
- wheels were balanced when tires were purchased, and rotating front/back revealed the same problem just on any tire/wheel located at the front right.
- in straight braking, the front right ABS activates very quickly (Brembo blanks and PBR metal masters) as it loses traction, but the front left does not
- front right pads never mated well and have rough patches
- prior to seeing this problem, when changing the front suspension, I discovered that the hub connected to the lower A arm and axle tends to want to be higher than the suspension assembley's mounting fork. So to align the holes for the connecting bolt, you have to push down on the hub some how... and my right side was SIGNIFICANTLY harder to push down than the left
PLEASE HELP ME, I can't figure out what is wrong and no mechanic has been able to identify it either.
chimchimm5's Avatar
Default Re: Wierd tire wear; looks like camber but it's not! (chimchimm5)
Here's a crappy phone picture of my tire from the BACK of the front right tire.
Old Nov 17, 2005 | 08:07 AM
rice a roni's Avatar
toe could be a suspect.
Old Nov 17, 2005 | 08:17 AM
BlkslowCRX's Avatar
Bumping because I am having the same problem with my 92 dx I cant figure it out
But im on Zeal Function 6 Coilovers with 99-00 si front suspension with 7in wide works
Old Nov 17, 2005 | 08:30 AM
AutoXer's Avatar
Default Re: Wierd tire wear; looks like camber but it's not! (BlkslowCRX)
Looks like toe wear to me. There's a big difference between 'in spec' and 0. I had mine set within spec after I lowered it, and I started to get wear; got it down to 0, and it's been fine since.
Do you happen to have the specs of your alignment? It's weird that it's just one tire, so something may be bent...
Old Nov 17, 2005 | 09:51 AM
JDMEK206's Avatar
check if something is bent on the right front. your toe is off a lil bit.
Old Nov 17, 2005 | 09:59 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimchimm5 &raquo;</TD></TR><TR><TD CLASS="quote">- in straight braking, the front right ABS activates very quickly (Brembo blanks and PBR metal masters) as it loses traction, but the front left does not
- prior to seeing this problem, when changing the front suspension, I discovered that the hub connected to the lower A arm and axle tends to want to be higher than the suspension assembley's mounting fork. So to align the holes for the connecting bolt, you have to push down on the hub some how... and my right side was SIGNIFICANTLY harder to push down than the left.</TD></TR></TABLE>
So one or more suspension pieces is slightly bent, the pad mounting cradle is twisted or bent and perhaps you have a deformity in your hub that causes abnormal radial resonance at certain speeds. This is all a result of normal driving. Potholes and bumps in the road do significant damage over time: our cars aren't engineered for strength, after all .
If it's not too quick of wear, I'd see if you could get an alignment place to experiment and maybe cancel out the suspension damage with some creative alignment options.
Old Nov 17, 2005 | 10:41 AM
92accordexpower's Avatar
i have a similiar problem on my 94 civic 4dr.
it shouldn't be toe. when toe is off, the steering wheel had to be turned to compensate, and both tires will wear evenly as they skid down the road. do you ride alone in the car alot? if so that will do it. when you get an alignment you're not in the car. when you sit down, depending how strong your springs are, they most likely compress. when your left front spring compresses, your camber turns negative, and this will wear a tire. i'm saying this based on what you've said, i can't tell good enough from the picture.
Old Nov 17, 2005 | 10:42 AM
i read wrong, front right is wearing....
makes it a little more confusing...
but still not toe
Old Nov 17, 2005 | 12:55 PM
AutoXer's Avatar
Default Re: (92accordexpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92accordexpower &raquo;</TD></TR><TR><TD CLASS="quote"> the steering wheel had to be turned to compensate, and both tires will wear evenly as they skid down the road. </TD></TR></TABLE>
Not necessarily. If he bent something (which I suspect, since only one tire is wearing) he could have his tires look like this | / when looking down on them. So one tire is pointed down the road, and the other is at a continual slip angle, which is how toe causes wear.
If your steering wheel is turned, but the car drives straight and you have even tire wear, that is called thrust angle. This is when toe is set correct at each axle, but not with respect to each other or the centerline of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92accordexpower &raquo;</TD></TR><TR><TD CLASS="quote"> when you get an alignment you're not in the car. when you sit down, depending how strong your springs are, they most likely compress. when your left front spring compresses, your camber turns negative, and this will wear a tire. i'm saying this based on what you've said, i can't tell good enough from the picture.</TD></TR></TABLE>
That's just not true, otherwise nobody would have tires that wear evenly.
Old Nov 17, 2005 | 01:00 PM
rasinhell's Avatar
Default Re: (AutoXer)
i before e, except after c.
Old Nov 17, 2005 | 01:06 PM
Slow EJ8's Avatar
Wierd, my front right has that same type of wear.... I am sure something is bent in mine though, alighnment shop said so.
Old Nov 17, 2005 | 05:46 PM
BlkslowCRX's Avatar
Default Re: (djstation)
i though the same thing i replaces the Lcas with new Stiffer Bushings and that didnt help what else could be bent UCA?
Old Nov 17, 2005 | 06:12 PM
littleredcivic's Avatar
Default Re: (BlkslowCRX)
just out of curiousity, are your lower plastics or fender linings rubbing on your tire during movement? on my friend's SC300 turbo, he has Supra brakes inside some 18 inch Volks and a Vertex body kit. He had the same wear as you have and couldn't figure it out. I looked under the car after jacking it up and noticed there was a splash cover that COULD move at high speeds...so i bent it as far as i could and sure enough, contact. just an idea...
Old Nov 17, 2005 | 06:21 PM
Stoich EG2's Avatar
Default Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">just out of curiousity, are your lower plastics or fender linings rubbing on your tire during movement? on my friend's SC300 turbo, he has Supra brakes inside some 18 inch Volks and a Vertex body kit. He had the same wear as you have and couldn't figure it out. I looked under the car after jacking it up and noticed there was a splash cover that COULD move at high speeds...so i bent it as far as i could and sure enough, contact. just an idea...</TD></TR></TABLE>
no.
beanbag
Apr 5, 2009 09:55 PM
yOnKiNaToR
Oct 16, 2008 06:39 PM
eg6hatch
Suspension & Brakes
45
Aug 25, 2006 10:01 PM
Civic-Stiz
Jun 21, 2002 06:15 AM
