Tranny pops out of 5th gear
Old Nov 16, 2005 | 02:06 PM
dynamo's Avatar
Default Tranny pops out of 5th gear
I recently changed the clutch/flywheel in my 00 GSR motor/tranny to an Exedy clutch/flywheel combo. Since then, the tranny has been popping out of 5th gear on the freeway, usually around 70 - 75 mph when I let off the throttle. Any idea what could be causing this? I never had this problem before I changed the clutch, so could it be something that was done wrong during the install?
TIA
Old Nov 16, 2005 | 03:34 PM
gsr dood's Avatar
Default Re: Tranny pops out of 5th gear (dynamo)
low tranny fluid. happpened to me i had a leak in the rear main seal. check ur axles too u mite have a seal lost.
Old Nov 16, 2005 | 04:11 PM
dynamo's Avatar
Default Re: Tranny pops out of 5th gear (gsr dood)
We just filled the tranny this weekend, and it was toppped off with 2+ quarts of honda MTF, so I don't think fluid is the problem. I will check tomorrow when I am back in town, but I doubt that's the problem.
Anything else I could check on?
Old Nov 17, 2005 | 06:37 AM
LSracing94's Avatar
bad synchro on the tranny maybe??
Old Nov 17, 2005 | 06:57 AM
old_school_dohcvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">low tranny fluid. happpened to me i had a leak in the rear main seal. check ur axles too u mite have a seal lost.</TD></TR></TABLE>
low on tranny fluid
Old Nov 17, 2005 | 07:56 PM
gsr dood's Avatar
Default Re: Tranny pops out of 5th gear (oldschooldohcer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamo &raquo;</TD></TR><TR><TD CLASS="quote">We just filled the tranny this weekend, and it was toppped off with 2+ quarts of honda MTF, so I don't think fluid is the problem. I will check tomorrow when I am back in town, but I doubt that's the problem.
Anything else I could check on?</TD></TR></TABLE>
make sure u put 2.2 - 2.3 quarts even the littlest amount will affect it 99% of the time wen 5th pops ur low on tranny fluid...if u run low for an extended period of time, then 5th gear can totally be ruined.
Old Nov 17, 2005 | 08:16 PM
projectTeG's Avatar
you said 2+ quarts...so how much did you put in?
Old Nov 17, 2005 | 10:03 PM
SlammedDC2's Avatar
Semper Fidelis
Check your linkage
Old Nov 18, 2005 | 12:40 AM
riceball777's Avatar
sounds like a fuked of trannie
time for another one or a rebuild
my old b16 trannie started grinding 3rd then 4th then started poping out of gears.
this would be a great time to upgrad to a jdm b16 trannie with lsd
they can be has on http://www.hmotorsonline.com for $900 or 600 for non lsd
Old Nov 18, 2005 | 08:52 AM
dynamo's Avatar
Well, I got it up on jackstands last night, and when I opened the fill plug the fluid came pouring out (not just dripping out). So, I let it flow out until it was dripping out slower, closed it up and drove.
Same results - it popped out twice on the way to work. I also noticed that it usually pops out at lower speeds (like 60 - 70) when I am decelerating/off the throttle from going faster (75+).
What else could I check for in terms of the shift linkage?
Also, if the tranny is messed up, what part could be potentially messed up and about how much am I looking at in repairs?
And, are there any other things I can check for before I pull the tranny and take it in?
Old Nov 19, 2005 | 04:06 PM
dynamo's Avatar
So it continues popping out of gear on the freeway, even after I drained the fluid to the correct level. Someone mentioned something to me about a clutch adjustment - could this be something that is causing the problem? I am trying to eliminate as many variables as possible before I have to tear off the tranny.
bobby_booshay
Aug 7, 2004 10:09 PM
743power
Oct 9, 2003 11:41 PM
hdeuce
Sep 3, 2003 02:02 PM
jlamaster
Jul 30, 2003 12:12 AM
svtec
May 20, 2003 10:21 AM
