b16 pistons in b18c1 will it clear
Old Nov 16, 2005 | 12:15 PM
truteg801's Avatar
Default b16 pistons in b18c1 will it clear
will b16a pistons in a b18c1 block will it clear? will there be valve interfearence???
Old Nov 17, 2005 | 12:29 PM
truteg801's Avatar
Default Re: b16 pistons in b18c1 will it clear (truteg801)
come on
Old Nov 17, 2005 | 05:57 PM
PURPLETERROR aka BIGMATT's Avatar
yes, no
Old Nov 18, 2005 | 08:07 AM
truteg801's Avatar
thanks
Old Nov 19, 2005 | 07:52 PM
Deetz's Avatar
Crazy Honda Guy
Yes, its been done many times, compression ratio of 11.3:1
A serch would produce the same answer if you look around.
Old Nov 19, 2005 | 09:49 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Deetz)
what cams my friend
Old Dec 3, 2005 | 05:20 PM
xyzalvarez's Avatar
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">what cams my friend</TD></TR></TABLE>
living up the dead...........
what about buddy club 3+ cams?....
with pr3? p30? or P73-JDM? pistons....
how to check the clearance?
Old Dec 3, 2005 | 06:18 PM
civicstar's Avatar
it will clear by alot still, i have a ls with ctr pistons that are .40 over and my head is milled down to the max. and i have skunk2 stage 3 cams and it still clears. and a LS stroke is bigger then a GSR so theres not much room for me but it still clears
Old Dec 3, 2005 | 08:03 PM
xyzalvarez's Avatar
Default Re: b16 pistons in b18c1 will it clear (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">it will clear by alot still, i have a ls with ctr pistons that are .40 over and my head is milled down to the max. and i have skunk2 stage 3 cams and it still clears. and a LS stroke is bigger then a GSR so theres not much room for me but it still clears</TD></TR></TABLE>
....this really gives me peace of mind using P30 pistons on stock head..
Old Dec 4, 2005 | 08:48 AM
civicstar's Avatar
Default Re: b16 pistons in b18c1 will it clear (xyzalvarez)
yep, not much room for error, timing slips atleast 1 teeth, the whole motor is done, when i first got the pistons, i had to shave down the "in" signs on the piston because the clearance of the head was milled down so much, it left the "in" stamped onto my head, ehhehe everything clears but had to find custom valve lash settings for the valves due to the clearance
Old Dec 4, 2005 | 09:52 AM
xyzalvarez's Avatar
but the how much CR are u running?
just to slap the CTR pistons on a stock GSR u will get like 12...whoa!.....
im planning to use some pr3 or p30 pistons, stock head. (11.3 aprox)...
i think i wont get any "up" stamped on the head right?
Old Dec 4, 2005 | 11:29 AM
civicstar's Avatar
Default Re: (xyzalvarez)
nope you wont, my CR is well over 13.2. i only got it cuz the head milled and hte stroke on the b18b. youll clear by atleast 2mm even if u had the ctrs. with the p30s pr pr3, there wouldnt even be a doubt that itll clear. there would be alot of room.
Old Dec 4, 2005 | 11:31 AM
xyzalvarez's Avatar
thnkx man for clarify
94EG2B18
Dec 15, 2011 09:31 PM
B16A CRX
15
May 28, 2007 01:34 PM
joethejoeman
Feb 7, 2007 01:42 PM
91ls-v
May 27, 2005 01:39 PM
philafelman
19
Dec 16, 2003 06:52 PM
