F/S JL 500/1 Mono Amp.
Old Nov 16, 2005 | 09:31 AM
sikc's Avatar
Default F/S JL 500/1 Mono Amp.
I'm posting this up for my friend... need pics? they will be up soon. throw me some offers.
Specifications:
* Rated Power: 500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power: <0.05% @ 4 ohm
* S/N Ratio*: >95dB below rated power
* Frequency Response: 5 Hz-500 Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
Features:
* Differential-Balanced Input Topology: (1 pair of inputs)
* On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
* Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
* Infrasonic Filter: fully-variable 24dB/octave from 15-60 Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual mono speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Modified by sikc at 7:43 PM 11/16/2005
Modified by sikc at 12:30 AM 11/18/2005
Old Nov 16, 2005 | 11:04 AM
sikc's Avatar
Default Re: F/S JL 500/1 Mono Amp. (sikc)
just received the pricing information...
it will be $260 + shipping.
Old Nov 17, 2005 | 03:30 PM
sikc's Avatar
willing to go lower if needed. BUMP.
GundamONE
Audio / Security / Video
Sep 21, 2003 09:52 AM
91hatchcivic
Apr 15, 2003 09:01 AM
